hakunamakaka
My first impressions of the A6 are very positive. I mainly use it as a streamer feeding my R2R DAC. The setup was super easy, intuitive and it is a joy to use the unit. The menu is logical, operation is quick and smooth. Quite a relief after the glitchy Zen Stream.
When it comes to sound, as a streamer only it is a step up from the Zen Stream, but the Zen Stream's sound is still very good for the money. The A6 sounds more neutral, more reference. The soundstage is bigger, airier and the resolution is higher with better detail retrieval. The Zen Stream in comparison is still very nice, but somehow a little warmer and thicker, less detailed.
I only tried the internal DAC of the A6 briefly, but it is surprisingly capable. Again, very clean sounding with good space and details, I think it is easily on the level of RME ADI-2, although perhaps sounds a bit more neutral than the German DAC. Switching to my Pegasus with upgrade fuse the R2R technology still gives me a more natural and lifelike sound with better textures and more depth, but I am positively surprised at the DAC performance of the A6. Most people should be happy with using the internal DAC.
It is a bit of a shame that the A6 currently is not supporting digital in/digital out to external DAC, hopefully that will come with a future firmware upgrade. Right now I use USB out to my external DAC, but I would like to connect a computer with USB-C to the A6. I will probably try RCA interconnect cables to my amplifier from the A6 as my external DAC is connected with balanced XLR. Changing sources would take a couple of switches, but I would not need to unplug any cables.
Did you matched against Zen Stream with stock PSU ? With latest firmware upgrades I actually see no issues with Zen stream so still curious if it’s worth the chase of Eversolo.
In back of my mind i might even ditch digital as primary source and get back to vinyls
