moriez
Dated or Classic?
I like your style
Dated or Classic?
You could try an RCA 6AS7G or if you can find a 6080 Chatham/Tung-Sol for power and some RCA VT-231 6SN7GT or Sylvania 6SN7WGTA for drivers. These won't break the bank and surely improve on what you already have.Anyone have tube rolling recommendation for the M5 Miflex on top of the tubes I have (listed below) that won't break the bank in 2023?
I am currently rolling:
Winged "C" 6AS7G
Tung-Sol 6SN76GTB (my default)
PSVANE 6SN7 Tennis Ball
PSVANE 6SN7 UK Black Plates
I have same amp + same output tube and same TS input tube - did some rolling and unfortunately, if you are going to stay within the 6SN7 type family, unsure what you would consider "breaking the bank", but imo, anything that sounds noticeably better within 6SN7/6F8G/6C8G is typically not cheap, and or, difficult to find quality NIB/NOS conditioned tubes. Ofc, this is just my opinion.Anyone have tube rolling recommendation for the M5 Miflex on top of the tubes I have (listed below) that won't break the bank in 2023?
Winged "C" 6AS7G
Wieslaw recommended this amplifier for the Meze 109 Pro to me. I will ask him again.With 40 ohms/112 dB (Meze 109 Pro) wouldn’t a transformer-coupled design be more fitting, or does Wieslaw think H22M is fine with these specs?
Is there a fully balanced Eufonika amplifier that Wieslaw builds? Wieslaw recommended the H22M for my setting knowing that I have the Musician Pegasus and the Meze 109 Pro.As well, Pegasus has balanced out, maybe consider a fully balanced version, rather than ‘just’ dual-mono.
I will ask him for this. Thank you!And, I would consider a potentiometer upgrade, it's relatively inexpensive.
Does this mean, the Eufonika sounds indistinguishable from your solid state amp for you?Guess what: the Eufonika is so good that I would not pass an ABX test, sure of it.
No, what I think he means, is the Eufonika sounds so much better than his solid state amp that there is no point quibbling over quibbles - the Eufonika is filled with joyous electron clouds drenching his phones in pure sonic bliss. Pretty sure that's what he meant.Does this mean, the Eufonika sounds indistinguishable from your solid state amp for you?
Yeah, this is what I wanted to read!No, what I think he means, is the Eufonika sounds so much better than his solid state amp that there is no point quibbling over quibbles - the Eufonika is filled with joyous electron clouds drenching his phones in pure sonic bliss. Pretty sure that's what he meant.
Hi together, I asked Wieslaw for a potentiometer upgrade and he recommended to take the TDK 2CP 2511.What potmeter upgrade are you considering?
Great recommendation, thank you! I will take this option!In case you need to daisy-chain the amps, a set of passthrough connectors on the Eufonika amp might also be worth considering.
I asked him once more and he again said that the H22M will be a good fit for the Meze 109 Pro.With 40 ohms/112 dB (Meze 109 Pro) wouldn’t a transformer-coupled design be more fitting, or does Wieslaw think H22M is fine with these specs?
There is, and it's on Etsy.I don’t think there is a fully balanced one. But I’d like one.
