g0ldl10n
Sounds like possible grounding issue to me.Update:
UltimatE arrived a few hours ago in good health, no wonder, the double packaging was perfect.
UltimatE looks better in the original than in photos, a positive surprise. I'll give myself a few more days until I'm patient enough to take the first suitable photo. Now I want to listen to music.
A humming problem needs to be solved: The humming occurs even without a connection cable to the source device, so it comes from the power cable. Depending on the position of the volume control, the hum changes its sound and position from right to center. I was hoping the upstream Furman AC-210 would prevent this. Tips are welcome...
Despite the hum and even in its current new condition, UltimatE leaves my Violectric V222 out in the cold. There is a difference of two classes, this with Eric's standard 6Y6G tubes.
My expectations were exceeded; such an improvement in sound was unimaginable for me.
Matt, thank you
FOR TESTING ONLY grab a ground lift plug for a few bucks and see if the hum goes away.
I experienced same exact symptoms in my amp which ended up being a grounding issue, which I first isolated by lifting the ground.
