UntilThen
- Jun 16, 2015
Looked up this fuse, It says "5*20mm Acoustic rhyme blue nano oil-immersed fuse hifi audiophile audio amplifier CD decoder bile machine oil-filled fuse".Its $20 for that aucharm fuse, and I've already guaranteed you it will sound better than the stock fuse.
I don't think you'll find a lesser fuse inside that fuse if thats what you're worried about.
I'm gonna try this fuse this time.
https://www.aliexpress.us/item/3256....0.0.191a38dah5lysU&mp=1&gatewayAdapt=glo2usa
… helps the fuse to ‘digest’ the complex waves of electricity & to give simple ‘nourishment’ to the amp?Looked up this fuse, It says "5*20mm Acoustic rhyme blue nano oil-immersed fuse hifi audiophile audio amplifier CD decoder bile machine oil-filled fuse".
Not sure what function bile has in the fuse.
I was curious about their use of “Bile” in adverts, it seems to be alluding to the youngsters of today using “Sick” to describe something. So a ”Sick” machine in China is a “Bile” machine. I wouldn’t want either, I’m really happy with my McChamplifier machine sounding fantastic listening to B B King with Eric Clapton.Looked up this fuse, It says "5*20mm Acoustic rhyme blue nano oil-immersed fuse hifi audiophile audio amplifier CD decoder bile machine oil-filled fuse".
Go for EL83 instead of EL84. Your amp seems to have operating point for output stage under 250V. Tubes are cheaper, sound the same. You can buy Telefunken EL803S and use in the same adapters and that is a spectacular tube. EL84 is much more expensive. I tried recently EL83 and EL84 and for our headphone amps sound the same.
From my understanding, each amplifier has a fixed operating point for each stage. This means a pair of Vplate and Iplate. Based on that, the circuitry which surrounds the tubes is adapted (bias and so on) to keep the tube at that operating point. If that is set, let's say, to 200V and 20mA (my particular case) it does not matter if you put a tube which allows 550V Vplate or 250V Vplate on it. The anode will stay around 200V. It's true that you should use a tube which has a slightly higher max anode voltage tolerance than your operating point (at startup there are some things going on) but in my opinion EL83 and EL84 should work at the same Vplate/Iplate in your amp. Of course, tubes allowing higher voltages are much more expensive, like EL84 is compared to EL83, but for us, it does not mean anything. EL83 and EL84 made from the same manufacturer will sound very close, like 6Y6 (max 200Vplate if I remember correctly) sounds compared to 6V6 (max 350Vplate). If you use 6Y6 I bet your operating point is under 200Vplate. EL83 works as a charm. Of course, I might be wrong. You can ask Eric.Yeah problem is that the amp seems to perform better with tubes that require higher voltage like 6F6 and KT66.
