Appreciate the replies from both of you on this, Hypops and VNandor. And have read and looked at all of the above material you've referenced.
I think there is still something about the differences between EQ-ing in the digital and analog domain that I'm missing in this discussion. And will probably have to go back through some previous threads to maybe find it, which could take some time.
I think this video helped me to understand and visualize a few of the concepts discussed here a little better though, fwtw.
No doubt. I've become increasingly fascinated by (and more than a little obsessive about) EQ over the past year or two. It's one of the few areas in music that brings together music creation, production, reproduction, and listening. It's incredibly technical and incredibly subjective at the same time. Every recording engineer has their own unique philosophy of EQ (as does just about every armchair EQer).
Now you've got me intrigued by this mystery explanation. As far as I understand minimum-phase EQ, digital just does digitally what analog EQ already does: shift phase to attenuate or boost certain frequencies.
@VNandor reaffirms above what I had assumed. Digital sounds functionally identical to analog. But that doesn't mean there isn't more nuance than that, and like I said above, seemingly
every recording engineer has their own philosophical dogma when it comes to EQ. Just like there are diehard analog-only audiophiles, there are probably similar divisions among recording/mastering engineers. But that's just a guess. Now you've got me super curious to hear the case against digital EQ. I'll have to do some digging...
It absolutely does affect the way you hear things if you invert only one of the channels even on headphones. You really should try it, it sounds surprisingly "different" (bad IMO). I used audacity to do the phase inversion.
Whoa. I just tried inverting phase in one channel using Roon's "Speaker setup" filter. Not what I expected at all. Not only is it audible;
it is way more audible through headphones than it is on speakers! Weird. I guess that means our brains are good in the other direction. Rather than realign the two different phases, your brain makes them even more distinct than when they interact in space. And more bizarrely, the waves don't interact in space, but they do interact in your head. Complete with phase cancellations and everything. I mean, they're neural signals at that point. They're no longer sound waves, but they still interact as if they were... The effect is even more pronounced than it is in space. Wow. Speaks strongly in favor of folks who argue that our ears/brains are more sensitive to timing imperfections than we assume.
If I understand this correctly, then, the reason that minimum-phase EQ works well on headphones without the same "phase smearing" that can happen with speakers is
not because a headphone's channels are isolated from one another. Based on what just happened when I inverted phase, the reason you can EQ headphones so well is actually because there's no "room" to worry about and therefore you can EQ both channels identically... which means you don't adversely affect their phase alignment. Maybe? I really dunno. I'm just hypothesizing. I think that makes sense, though.
