jaakkopasanen
Thanks for the kind words!Hi Jaakko,
First of all, I honestly can't thank you enough for all the work you've put into AutoEQ. I've been using AutoEQ for months now and I cannot understate how revelatory it has been: this is the most fun I've had with headphones in years. For me, AutoEQ is now just as, if not more important, than the headphone itself. Recently I've been playing around with sound signatures, and I love how I can almost "audition" any other headphone I might be interested in (or at least its general sound signature).
I had a question about AutoEQ that I was wondering you could answer. I've equalized both my HIFIMAN HE4XX and HIFIMAN HE400i 2020 to the Focal Clear's sound signature (with a 1.7dB bass boost), and I was wondering why the target curves for both results' generated graphs (attached) are different.
Here are the commands I used:
HE4XX to Focal Clear:
python autoeq.py --input_dir="measurements\oratory1990\data\onear\HIFIMAN HE4XX" --output_dir="my_results\[UAPP 10-band Parametric] HE4XX to Focal Clear (1.7dB Bass Boost)” --compensation="compensation\harman_over-ear_2018_wo_bass.csv" --sound_signature=”results\oratory1990\harman_over-ear_2018\Focal Clear\Focal Clear.csv” --equalize --parametric_eq --max_filters=10 --bass_boost=5.7 --max_gain=25
HE400i 2020 to Focal Clear:
python autoeq.py --input_dir="measurements\oratory1990\data\onear\HIFIMAN HE400i 2020" --output_dir="my_results\[UAPP 10-band Parametric] HE400i 2020 to Focal Clear (1.7dB Bass Boost)” --compensation="compensation\harman_over-ear_2018_wo_bass.csv" --sound_signature=”results\oratory1990\harman_over-ear_2018\Focal Clear\Focal Clear.csv” --equalize --parametric_eq --max_filters=10 --bass_boost=5.7 --max_gain=25
I thought that since the compensation, sound signature, and bass boost are the same for both commands, the target curve should be the same for both results. However, when looking at the automatically-generated graphs, the target curves are different (but the general shape is the same). I played around some more and found that if I use the same compensation, sound signature, and bass boost but a different headphone's (e.g., Sennheiser HD 600) measurement input_dir, the target curve shifts up/down (but retains the same general shape), so I'm sure there's a very good reason for why this is the case. I guess I'm just wondering why this happens.
Thanks for everything, and if you have time please let me know!
AutoEq shifts all the curves so that the error curve averages 0 between 100 Hz and 10 kHz. When error curve goes up, the target must go down to keep the correct difference between the error, target and the raw frequency response. Raw frequency response is always kept centered at 1 kHz. The shape of the curves don't change here, only their absolute location on the Y-axis.
