A few questions, is it possible to add negative bass boost?
I had this thing on my mind for some time, if AutoEQ is compensating FR for a Harman diffuse field, and HRIRs are doing the same, am I not doubling the compensation?
Reading
here, it implies it isn't, and one only needs to set bass-boost to 0. For Harman 2018 that's fine, but for Harman 2013 I don't know how much less (negative bass-boost) I have to set. Common sense tells me the same delta than for Harman 2018 (-4 dB) but any info on this regard is welcome.
For games I use cmss_game which is quite neutral so I don't need to disable bass-boost BUT, here comes another question: Am I supposed to be listening the game audio as if I were in a room with loudspeakers? or within the game environment (no Harman compensation)? In this second case what kind of compensation should I use? I observed in the
Road to PS5 video that they capture the HRIRs in an anechoic room, so a transparent FR as it can be should be preferable, despite not knowing what that means.
