billqs
- Jul 19, 2016
I understand. I guess I'll use the HE1000v.2 settings. SE has some different sound but it's not completely out of the ballpark.
Thanks!
Thanks!
Based on what I see in the Youtube video linked to that page, the AK player has graphic eq with ~20 filters and a parametric eq that has fixed center frequencies. The parametric eq isn't quite compatible with AutoEq because of it's fixed center frequencies. However you should be able to generate graphic eq settings for the AK player by setting the center frequencies with --fc parameter and quality with --q. In this case the required quality is 2.45 if I'm not mistaken.Hi Jaakko,
Can the EQ generate from AutoEQ can be used on new AK players with Eqlists?
https://www.astellnkern.com/eng/con...ew.asp?search=&word=&idx=1000125&page=3&no=89
Thank You
I did not hear any clipping
DIY Audio Heaven uses flat plate coupler for measurements ie. it's missing the outer ears. This kind of measurements are good in terms of reproducibility and useful for example in quality control. However they are not an accurate presentation of how human hears and therefor should not be used as a basis for equalization.Just tried your eq data out of curiosity with my 1more triple driver over-ear and all I can say is: it works!
The sound improves not only in the tonal balance and control, but also in soundstage, expecially depth. There is more "breath" into the music.
Quite impressed! Kudos! It's an amazing job!
On Mac OSX the only drawback is that AUNBandEq is limited to 5 octave bandwidth AFAIK.
Why don't you include DIY Audio Heaven measurements too?
