RRod
- Aug 25, 2014
Uhm, the O2 has 0.5 Ohm output impedance (from schematic), and the Leckerton UHA-6S Mk.II is quoted as having also 0.5 Ohm (I've also measured this from when I owned the UHA-6S Mk.II).
So no, they don't have different output impedance. If there is any difference, it's too small.
And the impedance swing of the UERM doesn't get below 5 Ohm, so based on that, it has more than a 1/10 ratio with both amps (orange plot is UERM's impedance):
How "rule of thumb" is the 1:10 ratio, though? It is odd that it's exactly where the impedance of the cans drops to its lowest that we eyeball the most difference between the amps. Innerfidelity gives the output impedance of the UHA as 0.4ohm, so could it be the case that this difference (0.4 vs 0.54) at these frequencies, where the headphones drop right to the "rule of thumb" realm, might start making a difference? I'm just asking; someone with da EE skillz can weigh in on the answer.
