I’m immune now from BS and haters
So, which specific dac have you owned that you believe has a large soundstage and great dimensionality for headphone use?
Agreed!! The fact is, no one has the "best"; there are just pros, cons and compromises. This is even more true, once loudspeakers and the room are added into the "best" equation.I get it everyone want to hear and believe their source and systems are the best or the giant killer to get the security but it it not
Its a second hand unit, so I'm guessing it has a solid amount of hours. Still, I'll keep my ears on it and let it settle and see how things go. Thanks for the tipCongrats! IMO, takes a whole 500 hours to fully settle.
I don’t disagree. I think dac2xv2 is more laidback and playback dacs are a bit more laidback than dac2xv2. Might want to try different power cables and different digital inputs. You may have better luck with a more laidback sounding streamer/front end.The DA2V2 seems promising so far. Only negative I noticed last night was it was coming across slightly bright in the highs compared to my Wavedream and other DACs, but I think that might change slightly as it gets more hours on it in my system. I'm guessing it has been sitting unused for some time.
I think this is true. The big factor is how sensitive the DA2 is to cables, esp power. With some it was a bit bright, but the current Shunyata Omega QR-s (yes, I'm sorry) is very smooth. I also found it quite not bright when I had some Transparent Reference interconnects a while back.I don’t disagree. I think dac2xv2 is more laidback and playback dacs are a bit more laidback than dac2xv2. Might want to try different power cables and different digital inputs. You may have better luck with a more laidback sounding streamer/front end.
After listening more last night and today, so far its sounding a bit less bright in the highs. I think that will partly be due to my ears adjusting, and also just the DAC warming up and settling within my system.I don't think it will ever be an easy going let alone darker or warm DAC, but I'll definitely experiment with inputs and power cables and what not, see how they effect things. Its only day 3, so I've got all the time in the world to play about with it allI don’t disagree. I think dac2xv2 is more laidback and playback dacs are a bit more laidback than dac2xv2. Might want to try different power cables and different digital inputs. You may have better luck with a more laidback sounding streamer/front end.
I've just switched to the toslink input, and will see how that sounds tonight. Thanks for the tipI think this is true. The big factor is how sensitive the DA2 is to cables, esp power. With some it was a bit bright, but the current Shunyata Omega QR-s (yes, I'm sorry) is very smooth. I also found it quite not bright when I had some Transparent Reference interconnects a while back.
I also find that optilink and toslink are more laid back inputs.
It has definitely subsided somewhat over time and I'm sure there is simply just my ears slowly adjusting vs day 1. Then through tweaking I've improved it further. I do think ill try different tubes in my preamp and see how that goes, but not yet. For me so far the positives, of which there are a lot, are massively outweighing the slight brightness/sharpness I was struggling with initially (and am much less so now.) Its a really good DAC@ufospls2 Has the sharpness gone away for you? What streamer/front end are you using?
