Hifi Boy
- Dec 10, 2016
Hey Effusion!
Thanks for recommending Mutec to me, I must admit that this was a good purchase. The unit itself is not cheap but for the price it does give good results.
I do have some other questions.
Once I've gotten myself a new DAC, I believe I'll go with the PerfecWave Power Plant, mainly because I'm running out of wall sockets in my apartment.
The thing I would like to know is once I buy that power supply, I believe I should also get a power conditioning cord, probably will go with WireWorld Electra.
So my question is, do I buy just 1 power cord which will go from the wall to the power supply, or should I buy a power cord for each and every audio component? The latter approach seems to me to be prohibitively expensive. I'm not sure whether the result of the initial power cord will be nullified by the stock power cords which will go from the power supply to the audio components.
The second question is with regards to the pure sine inverter you just mentioned. I researched a bit and found that it transforms the signal to look more like a real sine wave as opposed to a more on/off signal.
I'm not sure how exactly this would impact the audio quality, so could you elaborate on that? Also, I've seen some models for $100-$200 on Amazon, do you think these would give good results or should I go for more expensive ones?
I also assume, that only 1 unit would be needed which should be plugged into the power supply?
