petewebb
Hi All,
I got my 8900 all assembled and have been burning it in for a few weeks at this point. I absolutely love it. The build itself was pretty smooth. The only issues I had were that crazy “L” shaped joint connecting unit-4 to the speaker terminal board, OMG what a pain to solder until I discovered I could use alligator clips to keep the pins in place while I soldered them. Also unfortunately had a manufacturing issue with the chassis itself, where the front half of the chassis was ben inward toward the middle of the unit and the volume board and front faceplate wouldn't fit properly, but Victor was kind enough to swap it out for me and all fits fine now.
Things I added to the build:
After I completed the main build, all the LEDs came green on the first try, which was a relief. I’ve been burning in the unit for just over 75hours now with 2A3s and 12AU7s, with some periods of listening with WE300B and 12BH7As with NFB on and off. I think I prefer the non-NFB mode and the 12BH7As, but still haven’t made up my mind between the 2A3s and WB300B (they both sound awesome).
Overall I’m super happy with the TU-8900. It was a pleasure to build and sound is out of this world. Much different than my Mainline for sure. Now I’m just waiting for Jensen JT-11P-1’s to come back in stock, and I’ll try the balanced XLR input mod.
In the meantime, I got ahold of a completely original and in great shape Dynaco ST-70 from the original owner. Starting the super fun research into restoring and upgrading it. This DIY stuff is definitely addictive!
- Replaced 100uF and 47uF electrolytic caps with AudioNote standards, and the 6800uF with Nichicon KA’s
- Used Z-foil naked resistors for most of the cathode, headphones and NFB positions. For the 2x signal amplification resistors and the 2x 15uF positions I used AudioNote Niobium Non-Magnetic resistors. AutoNote standard for the rest of the 220Ks. Thankfully I was able to take advantage of holiday sales.
- Used Ohmite AGs 270uF 5w resistors. Started off with Kiwame’s but switched them out as I’ve heard good things about the Ohmite AG series.
- Started off using the VCap CuTF caps I got from victor but switched them out for Duelund 0.1uF 630Vdc CAST-PIO-Ag's and had to custom rig with heat-resistant zip ties and pads, silver wire and WAGO lever nuts(so I can take the board out if needed).
- Used pure silver wire to connect volume PCB to the mainboard. (thanks for the tip Whitigir)
- I used Mundorf silver/gold solder for all the audio path components, but honestly, that stuff is a huge PITA and I would rather saw my own arm off than use it again. It’s nearly impossible to get a shiny proper joint with that stuff at any heat setting. The WBT silver/lead stuff is so much easier to use.
