bigro
- Dec 18, 2014
It Looks like your post did come through. I definitely will be exploring more artists. Thank you for the recommendations. While Tidal is a little pricey one of the Advantages is the ability to explore new music, Although since Jay Z took over they seem to use the front page as a promotion ad for all that is unholy in the hip hop world.( I like Hip Hop/Rap but nothing I can think off that was recorded in the past 10- 15 years)
I did not really hear a difference otherwise with the tweeter grills on or off otherwise when i first took them off a month or so ago.When I revisited yesterday It's a Very small difference that can go almost unnoticed. The Foam Plugs Look like they are something you can make yourself as they seem to look like the foam used for the auralex sound isolation products used in studios but with a more open cell design.It actually looks like the foam used in some shipping products.
I look forward to your Impressions.
An Update on the Emotiva Amp. I have the new one Plugged in and have used it for 2 days now. The Thud is significantly less and not as concerning but it seems to be a characteristic of this amp. I may Just turn the Volume Knob Down and leave it on unless I will be gone for a few days.
