- Sep 20, 2016
I just got my Eros ll+ from Effect audio, I had burn in it around 100 hours, can say my impression on it.
Technical Specifications:
22 AWG
UPOCC Litz Copper / Silver
Proprietary Multi-Size Stranded design within single encapsulation
Flexible insulation (same as Leonidas)
New EA CF connectors and Y-Split
Notes:
A multi-sized stranded design within the same encapsulations enables the Eros II+ to achieve distinct highs and details due to the signal transmission speed in thinner cable strands, while the thicker size cable strands are usually employed for smooth bass and mids.
Past experiences have taught us that even though sound quality is a critical factor in determining an upgrade cable’s worth, the tensile strength and flexibility matters too. The reworked insulation features high tensile strength and flexibility, while adding as little weight as possible
8 Wire Braid is only available by “Bespoke”
Effect Audio uses certified UP-OCC materials only.
Eros ll + is a hybrid cable made from Ares ll + and Thor ll+, 22 awg thick wire with incredible soft insulation,
very easy to use, even when I am walking.
In fact, I have try different kinds of copper and silver hybrid cables from other brands, but they all gives a bright sound with copper kinds bass, and less treble extension.
But in Eros ll+, I can feel everything is different from my previous experience, very soft sound with a super good treble extension, even in the sound stage is wider, and
also with a deeply bass diffuse in my ear.
Anyway, this is the best hybrid cable I had heard, thanks SuYang and Eric from Effect audio team to give this good cable.
Thanks
Eddie
Thanks Eddie for the impressions!
Hi effect audio, which cable would you recommend for an iem that is warm, already has strong bass, that could use higher tonal definition, seperation and extension. I currently use a cable which is copper silver alloy.
PM Sent!
Stay updated on Effect Audio at their sponsor profile on Head-Fi.
