Just purchased an Andromeda and looking for a cable to use with my WM1A. Any suggestions?
What kind of improvements are you looking for?
The problem (for me) with cables (a day the 64audio U6) is that I have many different headphones that I like. Since many use different types of connectors, I would need to buy multiples of the same cable to compare. Case in point... The 64audio U6 uses different connectors than the Westone, Final Audio Design, and Campfire iems I am mostly using right now. This hobby is a money pit...
They are not bad if they go ovwr the ear and there is no memory wireSee I'm lucky in that all my favourites at the moment use 2-pin connectors, you can get MMCX to 2-pin adaptors but they are not the neatest looking solution.
Who sells these adapters?
Those are a bit of a hassle to use in my opinion as I feel that the connection length will be too long and stress the mmcx.maybe would work bwttee with angled connectors?Effect can make them, just send a message:
Stay updated on Effect Audio at their sponsor profile on Head-Fi.
Oh no we actually don't. It is actually not for sale. We have yet to find a solution to this particular connection without significant signal degradation as well as ensuring the built quality. As you can see in the pics, it's of a subpar built and is not a product that fit EA products portfolio and minimum level of workmanship. The adaptors above are a temporary interim solution for dealers to ease their demo/audition process until we can find a apt solution.
-Eric
Sorry Eric, my mistake edited
I do not know about long term use of adaptors, I agree an angled design would be best but then the angle of the memory wire from the 2-pin cable would be all wrong...
something like this ( https://www.instagram.com/p/BPCuODVDgAA/ ) but think of it with connectors reversed (female 2pin to male mmcx)
