- Oct 6, 2013
Just got my upgraded Chiron back
This cable is still my favorite pair up with Traillii. While I was waiting, switched back to stock 1960 4W, but it wasn't the same. Chiron brings more clarity and less coloring (more transparency) to the mids/vocals, actually brings Traillii mids a bit forward, and improves the imaging. I covered all this last year in my original Chiron review, should be still the same since wires didn't change.
The transformation:
The cable upgrade covers only the hardware, wires stay the same, and, obviously, I can't do side-by-side comparison. If there are any changes, it could be relative to a difference between the plug because I switched to TermX. For 100% purity, you would want PSquared/P-EA plug since it has a direct soldering to the connector without going through modular system. But who knows, the change could be minimum, and TermX is very convenient if you need to switch to 3.5mm or 2.5mm or maybe use their usb-c tips. But even with TermX, you will still find the same sandblsated polished Titanium casing as with PSquared plug. Which also looks like the same Titanium casing of the plug and the connectors in new Cleo II.
The new Y-Split looks really cool, a combination of sandblasted polished Titanium with Carbon Fibre. The titanium C-shin slider is retractable and hides in Y-Split, similar to the original one. The housing of connector shells is matching, also with a sandblasted polished titanium finish, just like casing of the plug.
The transformation:
