fkclo
- Jun 29, 2004
I browsed through my email exchange with Craig and found this about the function of the outputs at the back.
"The amp.... in the first run, meaning the RCA jacks would be a loop through for any input selected including the balanced input. This is neat because even with the amp off it acts like a passive switch box with balanced to se conversion. The Balanced output is the pre-amp out, but you can use a balanced to RCA interconnect to use it as a unbalanced line. "
So, it is also certain that the BA can be used as a pre-amp. I understand one can have a switch to select whether to select either the balanced or RCA jacks as pre-amp.
This is a unique feature which the Equilibrato does not have.
F. Lo
F. Lo
