Apr 2, 2013 at 5:50 PM Post #271 of 456
I thought you could run the kt77. Isnt it a drop in replacement?
Info from Craig : [size=12pt]If the KT77 you would like to use can tolerate 500V on the screen, and plate, it will work in the Electra[/size]
[size=12pt]Check your datasheet
[/size]
Apr 2, 2013 at 6:04 PM Post #272 of 456
Thanks for the info. It appears that the goldlion kt77 will be fine.
May 6, 2013 at 8:32 PM Post #276 of 456
Craig said he'd be shipping the amps out soon. That was 3 weeks ago...
May 6, 2013 at 10:42 PM Post #277 of 456
I should be taking delivery of mine sometime this week. (Just so the others on the first run know where things are along, I happen to be #1 on the list.) I know three have been assembled and are burning in.
May 6, 2013 at 11:18 PM Post #279 of 456
S/n001, that's gotta make you feel special marv :).
Looking forward to some impressions too...
May 6, 2013 at 11:48 PM Post #280 of 456
Awesome ! Looking forward to your impressions.
I don't think I will be adding anything new, unless the production unit sounds totally different from the one heard at CHANG-Fest, which had same the same parts including the cap upgrades. My thoughts and opinions are already well known of the Electra - and they do run counter to what most other e-stat owners consider is best.
May 7, 2013 at 12:49 AM Post #281 of 456
Thanks for the update, cant wait to get mine. I already have a bunch of tubes ready for tube rolling.
May 28, 2013 at 5:34 PM Post #282 of 456
It has been a few weeks. Did Craig get delayed?:confused_face_2:
May 28, 2013 at 6:16 PM Post #285 of 456
Craig went down to Nevada with his lawyer to test some transformers. Unfortunately while there he discovered mescaline and is now in the midst of a hallucinogenic adventure.
