kiertijai
- Sep 17, 2009
here is more info. I pasted what he has written to me. Please take a look.
I did a detailed test with VT52’s. They are much closer to a 45 tube, than a 300B tube. In the EC2A3 amp with 6 volts on the heaters, 330 volts on the plate and pulling 12 watts of plate power they will only do about 3 watts. I put a pair of E.A.T 300B’s in the same circuit turned the heater down to 5V and they put out 6.25 watts. In the BA running with the VT52 tubes on 5 volt heaters they will only do about 1 watt. They are very much like a 45 tube, but with better bass. I would say in a properly designed headphone amplifier setup to support the VT52 they would be more pure, clear, detailed without losing a deep soundstage. They will not work that way in the BA no matter what tubes you roll.
They are probably more appropriate with the 2A3/45 Balancing Act more than the 300B/PX4 Balancing. The output when working at 5V from 300B Ba is only 1 watt,
not enough to drive the AKG K1000, HE6. I may use them with the more sensitive headphones.
