https://www.audiovisualonline.co.uk...EYGpECl02rxi8UnvxvZ5r9UI3HkaAPM0aAoSXEALw_wcBWhere did you order it from? I'm looking to buy one as well.
Best price I could find in the UK.
They'll also price match it if it drops in BF deals...
Yes, definitely. Still trying to make up my mind about the Sparrow.Will leave my thoughts if anyone wants me to?
I'm in the US. But thanks.https://www.audiovisualonline.co.uk...EYGpECl02rxi8UnvxvZ5r9UI3HkaAPM0aAoSXEALw_wcB
On some devices you need to have the side of the cable with the EarMen lettering plugged into the Sparrow and the other side to your phone/laptop. Try that.Hey guys,
Just got the sparrow, not not working on my oneplus 8 Pro (plug and play)? Using the sub c to usb c lead that it come with.
Also tried on laptop (usb c to usb c) but also nothing?
Do I need to do anything prior to using?
Thanks - this actually worked, but sound only coming out of the right ear when using balanced output...On some devices you need to have the side of the cable with the EarMen lettering plugged into the Sparrow and the other side to your phone/laptop. Try that.
Make sure your balanced plug is fully inserted. If it has any sort of lip it might not go in all the way into the Sparrow's slightly recessed balanced port. Also I'm not sure what OS you're using but as far as I know Sparrow is only plug-and-play with Windows 10 and Mac OS.Thanks - this actually worked, but sound only coming out of the right ear when using balanced output...
Looking into updating firmware, but laptop not reading the Sparrow as an external source...
Grrrrrrrr...
thanks again - yes, fully inserted (no sound in left ear) and using Windows 10...Make sure your balanced plug is fully inserted. If it has any sort of lip it might not go in all the way into the Sparrow's slightly recessed balanced port. Also I'm not sure what OS you're using but as far as I know Sparrow is only plug-and-play with Windows 10 and Mac OS.
Very strange indeed then. Try flipping the cable over (logo face up then face down). Maybe there's some incompatibility with the cable or your devices.thanks again - yes, fully inserted (no sound in left ear) and using Windows 10...
Yes, I checked this and still no.Very strange indeed then. Try flipping the cable over (logo face up then face down). Maybe there's some incompatibility with the cable or your devices.
PS. Have you tried an SE cable to check that sound is in both channels?
Bizarre. Best you reach out to EarMen for advice.Yes, I checked this and still no.
The funny thing is that it picks up on tidal on both phone and laptop (plays through one ear), but wont pick up as a usb device so be able to select to run the update software through/from...
Sorry misread your original message - the SE is working on both channels. Its just the balanced that plays through one....Very strange indeed then. Try flipping the cable over (logo face up then face down). Maybe there's some incompatibility with the cable or your devices.
Earlier in this thread someone said the balanced port is slightly recessed so some plugs don't make perfect contact and so music plays out of one channel only. I suspect that's your issue here. Try switching the earpieces to see if it's not an issue with your IEMs also.Sorry misread your original message - the SE is working on both channels. Its just the balanced that plays through one....
AttachedCan I see a photo of your plug?
