IemLover
Dear Milkdudd
" I also suggest you take this OTG cable - it is amazing and improve the sound for sure - tested by my all audiophile friends.
OEOTG Digital Audio OTG Cable / OEAudio "
So, i ordered extra OTG cable with Earman Sparrow. The seller shipped my EMS parcel yesterday, i hope, i can get my package in next week.
I will test stock OTG cable and OEOTG cable, i will share here. (I think so, a member used OEOTG cable here)
iemlover
Milkdudd, i bought Earman Sparrow from Israel online store, i spoke with the seller before shopping, the seller suggested an additional OTG cable and he said:Well after another couple of hours of listening today and experimenting a little I have determined the following. If you set your Android phone to airplane mode you will have none of the buzzing, crackling and tick tick tick sounds. To get 100% silent it might also require turning off Wi-Fi (still experimenting with that). By the way these are the exact same sounds I get using my Mojo or Tr-amp. The same sounds about 10 times as loud that is. Maybe the added volume of the noise is because the Sparrow is powered by the phone rather than a battery. That's just a guess. In my case how often I hear the noise or the volume of it is not in any way related to how far the Sparrow is from the phone or the screen. Not saying that couldn't be relevant to somebody else's situation. With this said, listening to my Dunu Zen iems using the balanced connection in airplane mode with Wi-Fi turned off, the sound quality is magnificent. Something I could be happy with for a long time. Maybe some people can't use airplane mode because they need the phone available for incoming calls. The letters SOL come to mind in that case. I imagine a lot of people have Android devices that are no longer being used as a phone and could use it kind of like an iPod and get great sound.
iemlover
