EAC Foobar ASIO4ALL WASAPI Settings Pictorial
Feb 5, 2009 at 2:52 PM Post #106 of 251
Concerning EAC, does anyone know how to turn off the beep it makes every time it finishes converting to FLAC?
And this should really be stickied, helped me out loads so far.
Feb 5, 2009 at 2:57 PM Post #107 of 251
Mention it to Jude and the moderators.
Feb 11, 2009 at 6:58 AM Post #108 of 251
Thanks for this thread. It's brilliant.
Just one query, how do you change the Default Format to CD Quality on Windows XP? I can't seem to find the window for it. Is it already set to this on Default?
Feb 11, 2009 at 7:27 AM Post #109 of 251
-Go to your control panel
-Double click the speaker
-Choose your device from the list (Highlight it)
-Click properties
-From the best of my knowledge you should see some tabs up top and one of them should contain this info or a way to get to this info.
Feb 15, 2009 at 10:55 AM Post #110 of 251
Amazingly helpful. I have bookmarked this and will use it once I get my DAC. Thanks!
Feb 15, 2009 at 7:08 PM Post #111 of 251
You quite welcome, and feel free to ask any questions you may have.
Feb 16, 2009 at 10:36 AM Post #112 of 251
I have a couple questions about Vista SP1 and Foobar2000/WASAPI (keep in mind I am using a X-Fi set to Audio Creation Mode with bit perfect output):
1. Can I set the Default Format for Shared Mode under the SPDIF Out Properties in Vista to anything I want without it effecting Exclusive mode (i.e. Foobar using WASAPI)?
Basically, if I set the Default Format to 2 channel, 16bit, 48kHz, then will my Exclusive mode 2 channel, 16bit, 44.1kHz .wav files still play bit perfect without upsampling to 48kHz in Foobar2000 using WASAPI?
...or what if I set the Default Format to 2 channel, 24bit, 96kHz, then will my Exclusive mode 2 channel, 16bit, 44.1kHz .wav files still play bit perfect without upsampling to 24bit, 96kHz?
2. If I set Foobar2000 to 24bit Output data format, then will 16bit files still output at 16bit when in Exclusive mode?
Feb 16, 2009 at 10:48 AM Post #113 of 251
Tell me more about your rig. What is your X-Fi outputting to?
Feb 16, 2009 at 10:01 PM Post #116 of 251
Number 1 = yes
Number 2 = No
Feb 16, 2009 at 10:12 PM Post #118 of 251
Originally Posted by olblueyez /img/forum/go_quote.gif
Number 1 = yes
Number 2 = No
So why do you recommend folks to set Foobar2000 to 24bit output per your screenshot when using Vista SP1/Foobar2000/WASAPI? Shouldnt it be set to 16bit when playing 16bit files and 24bit when playing 24bit files to achieve bit perfect output?
Also, in general, what should we be setting Vista's Default Format to for Shared Mode? Should it be the maximum channels, bit depth and sample rate that our DAC supports?
Thanks for all the info, but this is a very confusing topic...especially when there is no way to test this stuff without essentially hooking up a high-end AV receiver that will tell you the channels, bit depth and sampling rate of the signal.
Feb 16, 2009 at 10:21 PM Post #119 of 251
Number 1 = USB or Optical?
Number 2 = yes
Feb 16, 2009 at 10:31 PM Post #120 of 251
This was in reference to S/PDIF Optical output
