- Jan 29, 2010
Today we are taking a look at the E1DA 9038D on Headfonia. Article by @Aerosphere
https://www.headfonia.com/e1da-9038d-review/
Does the different opamp implementation, make a significant presentation difference between the 9038D & 9038S ?Today we are taking a look at the E1DA 9038D on Headfonia. Article by @Aerosphere
According to the E1DA's website and my research, no.Does the different opamp implementation, make a significant presentation difference between the 9038D & 9038S ?
Nope. Sounded great out of the box, wouldn't say it sounds any different now (flashable filters aside).Do you guys believe in burn-in for the E1DA 9038SG3? And if yes how is sound supposed to evolve?
Thanks!
Am thoroughly impressed with 9038D and PDV21 .. and now becoming greedy!
Any chance to have 9038 Pro model with ESS Sabre 9038 pro chip anytime soon? Or with AKM AK4497 or 4499? Better still.. fully balanced with dual chips. Eagerly awaiting. The greed just doesn't end! Would like to have all such combinations from E1DA!
Some consolation may also work that at least the plan, for anyone at least, is in place!
My understanding was (is) that the E1DA units don't have a DAC in them at all in the traditional sense. It's something called PWM (Pulse Width Modulation) instead.Am thoroughly impressed with 9038D and PDV21 .. and now becoming greedy!
E1DA contains single ESS 9038QM DACMy understanding was (is) that the E1DA units don't have a DAC in them at all in the traditional sense. It's something called PWM (Pulse Width Modulation) instead.
The width of the digital pulse is varied to represent the 'curve' of the analogue waveform and then this digital signal is amplified enough to drive headphones.
https://en.wikipedia.org/wiki/Pulse-width_modulation
That's the beauty of these units. So I'd guess it's highly unlikely they'll switch to using traditional DACs ever.
Pulse Density Modulation is the binary language of a delta sigma chip. The E1DA's ESS chip uses this, and maybe this is what you were referring to.My understanding was (is) that the E1DA units don't have a DAC in them at all in the traditional sense. It's something called PWM (Pulse Width Modulation) instead.
Yes I know. They do not expect AKM factory to open before May 22 but that doesn't seem too far. For now 1 or 2 chips should be good enough for designing, tuning and for specs publishing. Mass production may start when factory starts production and dac chips become available in bulk.FWIW, AKM had a factory fire end of last year: https://www.converge.com/resources/news/supply-chain-disruption-news-akm-factory-fire/
So there might be a shortage and delays of their chips for some time (or maybe AKM chip prices may be even increased due to backlog/demand).
I took my info from the E1DA page where it says "PowerDAC V2 uses the same or similar Ti digital PWM modulator chip TAS5558 but of course different output stage for headphone"Pulse Density Modulation is the binary language of a delta sigma chip. The E1DA's ESS chip uses this, and maybe this is what you were referring to.
Practically all music that is recorded, stored and used commercially is in a binary language called PCM (Pulse Control Modulation) format. Imagine a piece of graph paper will be used to draw an electrical signal for the speakers. The X axis is time and the Y axis is the amplitude. In PCM, ones are filled to chart the sine wave's placement at a given time. So in binary terms, sixteen zeros would be the bottom of the sine wave, and sixteen 1's would be the top of the sine wave. (In a 16 bit file format.) DACs that use this file format are R2R/Ladder and Multibit.
Sigma Delta DACs use a different binary language to construct the electrical sine wave that speakers use. Instead of visualizing a piece of graph paper, imagine that PDM (Pulse Density Modulation) is more like a two dimensional topographic map. When binary 1's are primarily used, it is mapping the top half of the sine wave. The more times zeros interupt the 1's, the steeper the sine waves curve (in the positive Y axis). A whole bunch of uninterupted 1's map the curve of the top of the sine wave. When binary 0's are primarily used, it is mapping the bottom half of the sine wave. The more times 1's interupt the 0's the steeper the sine wave curve (in the negative Y axis). A bunch of uninterupted 0's map the bottom of the curve. (At least that is my understanding of it.)
Here is another example of the PDM language that sigma delta dacs use:
0101101111111111111101101010010000000000000100010011011101111111111111011010100100000000000000100101
Ah, does it. I must admit, I only have the PD v2.1E1DA contains single ESS 9038QM DAC
