E1DA DACs Discussion Thread (PDV2, 9038S, 9038D, 9038X, HiFiToy, HPToy)
Oct 29, 2020 at 11:13 AM Post #992 of 1,483
>>It picks up a huge amount of interference when using mobile data.
maybe this get to be solved
Warning: 9038D contains a high-sensitive I/V stage that may cause audible noise when your phone uses LTE 4G, 5g. Some newest hardware may have issues like "stuttering" with USB3(Macbook pro 2020, MS Sufrrase 2020, Lenovo Carbone 2020, Acer SF313-52-71Y7 2020). USB audio-bridge manufacturer was informed about that and we expecting the FW solution.
Oct 30, 2020 at 6:42 PM Post #993 of 1,483
Which better original 9038s g3 or susumu edition?
Oct 30, 2020 at 7:21 PM Post #994 of 1,483
Is the E1DA 9038S Gen 3 a safe and reliable device or does it still have those problems I read about suddenly changing mode and shooting music at maximum volume in your ears?
For iems type TRI I3 and Blon BL 03 is it ok?
Sounds Phenomenal with Tri i3!
I use them with 9038S G2 and G3 outside and works great with them. G3 is without the former problems. I never had this with my hiby r3. its more an android illness
Oct 30, 2020 at 8:13 PM Post #995 of 1,483
I
I just bought one gen3, planning to use it with R3pro. Is it just plug and play? Can I adjust the impedance thru Hiby or I should set it on the PC?
Oct 31, 2020 at 6:45 PM Post #996 of 1,483
ît is plug and play .. you have to set playmode to "storage" or what works.. then its just plug in an 9038S is like a Borg drone assimilating that dap :wink:
i have no clue what impedance will do ... you can flash different bios but its so subtle that i stick with standard
Oct 31, 2020 at 7:52 PM Post #997 of 1,483
People say they sounds the same on the discord group... Susumu has slightly higher specs but its more expensive so it's up to you to decide if you wanna go for the placebo or not. it seems that Ivan is a perfectionist and will try to improve the product ever so slightly each times a new batch comes.
Nov 3, 2020 at 3:15 AM Post #998 of 1,483
Nov 3, 2020 at 4:32 AM Post #999 of 1,483
Why are there 8 different files - what is the reason therefore - cannot find any documentaion
Nov 3, 2020 at 4:52 AM Post #1,000 of 1,483
Nov 3, 2020 at 6:28 AM Post #1,002 of 1,483
OK---Model 9038D
????---MCLK
Apo is the DAC manufacturer's default, Lin Slow is E1DA's default.
12MHz has less distortion, 25MHz has less noise.
noSTBY deactivates standby altogether, which can get rid of pops.
recommend is the 4th one.
