E1DA DACs Discussion Thread (PDV2, 9038S, 9038D, 9038X, HiFiToy, HPToy)
Dec 20, 2019 at 11:25 AM Post #526 of 1,483
Dec 20, 2019 at 2:58 PM Post #527 of 1,483
I am looking forward to the 9038D. Do the current 9038X get RF interference?
If you are asking about the 9038S, then at least on my LG v30 the answer is a definite yes. Seems to be related to noise from cellular signal, not wifi or Bluetooth, at least for me.
Dec 20, 2019 at 3:22 PM Post #528 of 1,483
For me and my Asus RoG Phone 2, there is no noise associated with either E1da device.
We should make a list somewhere of afflicted source devices.
Dec 20, 2019 at 6:31 PM Post #529 of 1,483
The 9038X is probably a no go. Or you mean the 9038S? 9038S Gen 3 is likely coming after 9038D. It will have everything the D have, tap change volume, newer USB Bridge (32/324, DSD) and EMI filtering. IMG_20191221_073106.jpg
Dec 21, 2019 at 2:48 AM Post #530 of 1,483
When was that posted, yesterday or a while back ? Thanks.
Dec 25, 2019 at 5:37 PM Post #533 of 1,483
This forum is bad for my wallet, but I have to check this out.
P1 orderd and a pdv2 to drive them, while at it also took the 9038s to drive some bl-03 on the go.
Merry Christmas me :wink: and now we wait.
P.s. all merry Christmas ofc
Dec 27, 2019 at 2:53 AM Post #534 of 1,483
Possible to use HPToy app to control EQ if you are hooked up to macOS using Audirvana+......?
Also, I guess from that unit heat the PDv2 is running in Class A ?
Dec 27, 2019 at 4:17 AM Post #535 of 1,483
Yes, you use your phone to EQ the Pdv2 while it is being used for your computer.
Dec 27, 2019 at 5:11 AM Post #536 of 1,483
Reading you signature p1+pdv2 must be heaven, care to elaborate on the topic I'm curious what kind of eq the p1 require to shine
Dec 27, 2019 at 10:08 AM Post #537 of 1,483
Thing is the eq of the E1da let's you eq really miniscule bands. Other eq setups will seem simple in comparison.
Dec 28, 2019 at 5:47 AM Post #538 of 1,483
There are two option for cable, OTG Cable and USB B to A, for y split which option to choose, please suggest.
Dec 28, 2019 at 8:03 AM Post #540 of 1,483
Thx
