AT Khan
- Nov 3, 2015
It is July now. Are there any news on the detachable cable version of the headphone?
Kind of
![biggrin.gif](http://files.head-fi.org/images/smilies/biggrin.gif)
What material is recommanded? Or should I buy the lawton kit? And doest it reduces the bass? Because I don't want that.
It shifts the bass from midbass to sub bass. The bass sounds tighter rather than thick. So it mostly depends on how you like your bass. If you like that thick, warm, slightly fuzzy bass then don't put foam in. If you like low, tight, dry bass then damp it. You can also go halfway as well. I used the Lawton kit, but I only put on the pieces that attach to the driver side and didn't put in the cup attached pieces or the foam.
Thank you for the answer! Should work fine with the Teak cups too?
I don't see any reason why not, but it may make the real cups too dry sounding if you overdo it. Be careful and make sure it's reversible.
Could you specify with the Lawton guide what part you exactly did? The step 4?
Yes. I put on pieces C, D, E & F. I didn't put on pieces A or B.
Do those foam strips stick or you have to apply something? And how can you make it reversible?
The rosewood has grown on me as well, I am finding it scales really well - preferring the rosewood with solid state amp, and the teak with tube. System synergy is truly an alchemy!!
Ironically, I find the ebony least attractive, well sonically, out the three. Which I find strange considering the clamour for them on the th-x00 thread.
Interesting. I went back and forth between the two and couldn't really make out any differences between the rosewood and the Ebony sonically. Chan said the same as well, that they measured identical and there was as much variation between cups of the same wood as there is between rosewood and ebony. Could maybe just be that you happened to get a cut of rosewood that really suits your preferences and a cut of Ebony that didn't. That's the thing with these wood cups, we speak as if every cut of the same wood sounds the exact same, when they don't. The difference isn't large by any means, but a cross grain cut and a quarter grain cut can sound subtly different because they resonate at different axes.
This is a great post because it perfectly predicts the wood grain of my cups, as shown below :
Ive not given up on my ebony, in fact I picked this set out in particular because of their distinctive wood grain. I shall persevere with them some more to see if my ears can adjust to them.
