So neither teak, nor lcd 2c are superior to aeon? Thats helpful. I have a 15 band hardware eq, so I get plenty of bass with the aeon
The Aeon is more of a technical revelation when the amplifier is right.
It must also be said that its 14 ohms are not easy to drive.
It needs enough power and also good technical amplifiers to exploit it.
I listen to it with the Hip Dac 2 for on the road and am very happy with it than with a dongel.
At home, I have a hybrid amplifier for it where it takes it up another notch.
The quality of the bass depends on the amplifier.
Personally, an Eq is suboptimal for planar headphones.
Certain areas are quickly ruined if you overdo it.
The Teak is even better in terms of power and good depth, but technically it is rather average.
And it also has a good slam.
It's true that the Teak is more for fun, the Aeon more analytical but still musical, it's rarely too much or too little.
The Lcd 2C is more an invitation to relax, which is not wrong.
It certainly has more slam on the bass than the Aeon.
The Lcd 2C can be analytical but doesn't come close to the level of the Aeon.
But it has completely different qualities, more relaxed, more accurate and more musical than the Aeon.
But even there, the amplifier is a bit important.
But not as important as with the Aeon.
The Aeon needs an amplifier that can handle low-ohm headphones.
The Lcd 2 eats up everything, with the Teak it's similar to the Aeon, but not quite as blatant.
It is more forgiving.
You can't get rid of that with EQ, it's simply an amplifier thing, if it's good enough, you don't even need EQ most of the time.
