evanft
- Dec 27, 2001
So I just got the 0204. It works great and I set up the ASIO output in Foobar so now the E-MU gets the correct sample rate. I have a couple questions, though:
1. Do I have to switch between 24 bit and 16 bit in the output devices menu any time I switch bit depth?
2. The windows volume still changes the volume coming out of the 0204. Is that supposed to happen with ASIO?
EDIT: Now it gives me this error:
"Unrecoverable playback error: The ASIO device does not support specified sample rate (44100Hz); please configure resampler appropriately"
It won't play anything at 16 bit/44.1 khz anymore. When I try, it selects 88.2 khz and gives me an error. It won't let me select 16 bit/44.1 in the sound devices section of the control panel, either. I can get 44.1 khz material to play if I change the ASIO settings to 24 bit. What?
