Dynamic In-Ear Monitors JD10 TC Is Officially Released!
10mm polymer composite diaphragm
To be the benchmark for entry-level sound quality, the JD10 TC features a carefully selected 10mm polymer composite diaphragm. This diaphragm is high in rigidity, low in distortion and is optimally damped. It delivers rich and full bass, which perfectly blends with the midrange and treble for a truly enjoyable sound. Additionally, thanks to meticulous acoustic tuning that leverages the diaphragm’s rigidity, the JD10 TC is highly resolving in a manner rarely seen amongst its peers, capable of reproducing even subtle audio details.
Dual cavity design
The JD10 TC employs a dual-cavity acoustic design, with separate damping control systems in each cavity. This precise control of air flow damping helps reduce distortion, which effectively enhances driver diaphragm movement and bass extension.
When listening to complex music, this design allows the JD10 TC to capture more nuances in bass notes – resulting in a refreshingly speedy and detailed bass.
0.033mm Japanese CCAW voice coil
To deliver higher quality sound from the driver, the JD10 TC utilizes a special ultra-fine Japanese CCAW voice coil, with a wire diameter of only about 0.033mm.
This voice coil, thanks to the wires’ thinness and properties of CCAW, significantly reduces the overall driver mass. As a result, it is easier to get the driver to produce higher volumes and also leads to improved transient response. The result is cleaner and more enjoyable sound.
External N52 high performance magnet
The JD10 TC employs an external magnet design. This allows for a larger magnet, which more effectively envelops the voice coil and results in more powerful sound. N52 high-performance neodymium iron boron magnets were chosen due to their abundance of energy and the ability to be made to apply their force over a uniformly broad area - ensuring the driver performs at its best.
3.7g light weight
The JD10 TC was designed from the very beginning to be a comfortable and light versatile pair of IEMs. Each JD10 TC ear piece weighs only 3.7g, among the lightest in its class and making it easy to go for long fatigue-free listening sessions.
Independent DSP chip, 6 built-in tuning presets
· Independent DSP chip, Built-in decoding, convenient HiFi
· 6 built-in tuning presets, multiple styles, freely switch up your listening
· Standard Type-C connector, compatible with all platforms and devices, like Win/MacOS/iOS/Android
High-purity oxygen-free copper cable
· 3-button in-line controls with a mic included, freely switch between HiFi music and voice calls.
· High-purity oxygen-free copper wires, help to transmit rich audio signals without fail.
* The JD10 TC is available on our AliExpress Official Store. Click the link to take it home right away:
https://www.aliexpress.com/item/3256807683508920.html
*Note: The JD10 TC adopts a non-detachable cable design due to cost limit. Please be considerate before purchasing.
Best regards,
Guangzhou FIIO Electronics Technology Co., Ltd.
Dual cavity design
3.7g light weight
aliexpress.com/item/3256807683508920.html[/URL]
Best regards,
ꄘViews:5
ꄀCollection
ꂃPrevious: null
