Dynamic In-Ear Monitors JD10 Is Officially Released!
Oct 10, 2024 at 9:02 PM Post #16 of 61
holy cow these cost less than a nice meal in in norway
how is that possible?
Oct 10, 2024 at 11:05 PM Post #17 of 61
Think I'm gonna wait for the 11.11 sale.
Fingers crossed on $6.94
Oct 11, 2024 at 1:24 AM Post #19 of 61
We always knew IEMs cost a fortune to make!
Oct 11, 2024 at 6:19 AM Post #23 of 61
I'll get interested after I receive my pre ordered DM13 CD walkman.
Oct 11, 2024 at 9:44 AM Post #25 of 61
10mm polymer composite diaphragm
To be the benchmark for entry-level sound quality, the JD10 features a carefully selected 10mm polymer composite diaphragm. This diaphragm is high in rigidity, low in distortion and is optimally damped. It delivers rich and full bass, which perfectly blends with the midrange and treble for a truly enjoyable sound. Additionally, thanks to meticulous acoustic tuning that leverages the diaphragm’s rigidity, the JD10 is highly resolving in a manner rarely seen amongst its peers, capable of reproducing even subtle audio details.
Dual cavity design
The JD10 employs a dual-cavity acoustic design, with separate damping control systems in each cavity. This precise control of air flow damping helps reduce distortion, which effectively enhances driver diaphragm movement and bass extension.
When listening to complex music, this design allows the JD10 to capture more nuances in bass notes – resulting in a refreshingly speedy and detailed bass.
0.033mm Japanese CCAW voice coil
To deliver higher quality sound from the driver, the JD10 utilizes a special ultra-fine Japanese CCAW voice coil, with a wire diameter of only about 0.033mm.
This voice coil, thanks to the wires’ thinness and properties of CCAW, significantly reduces the overall driver mass. As a result, it is easier to get the driver to produce higher volumes and also leads to improved transient response. The result is cleaner and more enjoyable sound.
External N52 high performance magnet
The JD10 employs an external magnet design. This allows for a larger magnet, which more effectively envelops the voice coil and results in more powerful sound. N52 high-performance neodymium iron boron magnets were chosen due to their abundance of energy and the ability to be made to apply their force over a uniformly broad area - ensuring the driver performs at its best.
3.7g light weight
The JD10 was designed from the very beginning to be a comfortable and light versatile pair of IEMs. Each JD10 ear piece weighs only 3.7g, among the lightest in its class and making it easy to go for long fatigue-free listening sessions.
High-purity oxygen-free copper cable
· 3-button in-line controls with a mic included, freely switch between HiFi music and voice calls.
· High-purity oxygen-free copper wires, help to transmit rich audio signals without fail.
· 0.78mm 2-pin detachable headphone cable, provides you with a way to further upgrade your headphones in the future.
* The JD10 is available on our AliExpress Official Store. Click the link to take it home right away:
https://www.aliexpress.com/item/3256807683508920.html
Best regards,
Guangzhou FIIO Electronics Technology Co., Ltd.
at this price, you dont think--you just click...especially when I have owned well over 12 Fiio products over the years. I know their IEMs are always good value and well made at any price point
Oct 11, 2024 at 9:48 AM Post #26 of 61
Oct 13, 2024 at 4:10 AM Post #30 of 61
It looks like an KZ EDC Pro re-badge, ordered anyway.
I get the feeling something like this also. Fiio putting their name on something else. Still no big deal, Fiio have a reputation of quality affordable goods, I'm really curious. I wonder if the Hugo2 will be sufficient
