cotdt
- Aug 29, 2005
Yes I think you are right rsaavedra. You can mod it to disable the protection mechanism.
Originally Posted by cotdt /img/forum/go_quote.gif Yes I think you are right rsaavedra. You can mod it to disable the protection mechanism. |
Originally Posted by rsaavedra /img/forum/go_quote.gif Eagerly waiting for that 100w pure class A speaker amp design from Gilmore. |
Originally Posted by cotdt /img/forum/go_quote.gif Why not convert your amp to the Dynamight? It will have 4 times the output of whatever the Dynahi has. Use one power supply for all four amp boards. It will get loud for sure, maybe even enough to destroy your speakers. |
Originally Posted by rsaavedra /img/forum/go_quote.gif I'm very happy with my Dynahi as it is, in single ended mode for headphones. Also, remember the Paradigms do have 4 ohm impedance in some frequencies. Not exactly comfort zone for the Dynahi circuit, not even the Dynamight I would guess. I think it's better to simply stick to a circuit that has been designed from scratch having in mind very low impedance loads like speakers'. So to drive speakers on a regular basis at sustained, loud enough volumes (for me 85 dB on average at 10 feet,) and with no worries for the amp circuitry or power supplies, it better be a speaker amp. |
Originally Posted by cotdt /img/forum/go_quote.gif The circuits for the dedicated speaker amps (Class A linear) are not very different from that of the Dynahi. The difference is mainly in the power supplies. So I don't see a point in building them because simply giving the Dynahi the right power supplies would accomplish the same thing. |
Originally Posted by n_maher /img/forum/go_quote.gif Regardless I'm glad to hear that nothing was permanently damaged in your amp. That's always a heart stopping moment when the music just stops! |
Originally Posted by phergus_25 /img/forum/go_quote.gif Just as a side note you could probably find some full range drivers that are 16 ohms and build some horns to give you ~100 db sensitivity as well as a higher ohm load. Thats just if you want a fun little [ |
11years later .....
do you guys think powering a pair of these
https://www.madisoundspeakerstore.c.../markaudio-alpair-10-gold-6-full-range-gen-2/
will stress the SuSy Dynahi ?
cheers
