DX320X #242 reporting in! Initial impressions: Extremely impressed and no regrets vs SP3000 yet!
The great:
> Low fuss unboxing experience. Very similar to other ChiFi brands with a simple cardboard box, no special wooden/leather storage box seen with A&K, Beyerdynamic or even Sony
> Frequency response tuning/tonality is neutral / natural. The sound descriptions as transparent, detailed and holographic is accurate. No "AKM velvet bass bloom" or Sony WM1ZM2 Signature tuning with extra sub-bass - just transparent reminding me of my sound impressions from Etymotic ER4S back in 2017-18. I'm already hearing new layers with my regular test tracks
> Volume gain is more than enough for IEMs but would keep away for hard to drive headphones. Roughly ~50/63 low gain and 35/63 high gain for Pop/Kpop and 63/63 LG and 40/63 high gain for classical for Sony IER-Z1R balanced. However, just sufficient SE power at 63/63 high gain for classical on my Beyer T1 600 ohm (time to reterminate my T1 to balanced!)
> Z1R's staging depth has improved a lot vs L&P W2 dongle likely due to much higher power output and dynamic range,. It was already quite wide on W2 so didn't notice much changes in width.
> Android 11 OS is very smooth and fluid to use - installed Spotify, Youtube and Netflix and tested with no issues - Audio issue has been fixed (vs 1 sec lag during my demo with v2.01)
> Screen is above expectations in size, refresh rates and color gamut vibrance - Youtube 4K videos look great (although downsampled to 1080p)! Comparable to current smartphones SOTA
> Weight is good in the hands - not too heavy like M17 but not as light current phone + dongle combo
> I don't know about burn-in but my unit sounds damn good out of the box! Leaving it with the burn-in cable overnight just in case
Some minor issues:
> Volume knob is not consistent during use, sometimes multiple presses needed to turn screen on/off
> My issue has a tiny bit of epoxy on the LED strip as well but not an issue for me
> Body gets quite warm during use (perhaps due to liquid metal) - but not a bother especially with leather case
> Initially Netflix didn't work on v2.03 but luckily works on v2.05
> Software updater via Settings didn't initially find v2.05 update - had to manually drop the file via SD card
Looking forward to more listening time when I get back up tomorrow!
