There is also another idea- IBasso could maybe implement some system to switch between 2-3 sound profiles. The software updates show that there are sonic changes between them, so maybe its possible to make it simpler, from Settings level in android, dunno, just the idea.
I am not sure they can "can" that and make it controllable at this point. I am thinking that the different "profiles" are simply a byproduct of different algorithms being used in order to make X amp module function properly. I could be wrong though. It has been known to happen....
On the other hand, I have not noticed any differences in the DX300 tuning when updating FW versions (even for Amp13 and Amp14).... But maybe my hearing is just not good enough to hear those differences at this point?!
Not as much differences on the Dx300. I was searching for any plausible explanations, and the best I could have come to the conclusions at the moment is that different IC chips have a different processing speeds. Even though all of them could have been conversion at 8X Over Sampling. The differences is that with faster speed, the more accurate the conversions and with the slower speed, the higher the noise shaping and random noises to cheat up and arrive at similar benchmarks on measurements (not the waveform accuracy)
Together with that, the higher the processing speed requires the lower power supplies ripples/noises. The differences in noises and voltage errors will result in a more dramatic changes to the conversions of the wave forms (as the chips do it errors corrections). In oppose of that, the slower speed with more noise shaping and errors corrections will be the least effected by power supplies noises and voltage errors.
Firmwares with different block of processings and or slight changes here and there will alter the way the systems are processing. This may increase/decreases the overall parasitic noises or errors and in turn be effecting the DAC chips.
So, the higher end the DAC chips, the more picky it is toward power supplies and it variations.
There are more to it, but it needs more time to perceive any further plausible explanations
Sounds plausible to me. I would not know the difference whether you were right on the money or not because I haven't done much research on this. But from what I DO know, it sounds pretty logical to me.
They released this week. Seems like none of the distributors have them yet, at least not on the US market. I purchased one directly from Paul a few hours ago, did the same when the Amp13 released. The waiting game starts.
I haven't got a clue regarding specs, going under the assumption that it will have a different taste vs the Amp13 (albeit mildly) but with better power output. I favor 4.4 pentacon as my daily driver so the new module has a certain appeal. Will post updates as soon as I have it, really curious to see how they compare to one another.
They don't come with a new liquid metal faceplate in case you have the Edition X. If I end up liking the amp14 above the amp13, I may have mod the faceplate on the 13 to fit into the 14. The faceplate dimensions for the amp12 are the same as on the 14 but I need that one for the Amp12EX. Really wish we had that extra faceplate but I'll make due.
Wouldn't be surprised that in the effort of optimizing hardware, meaning battery life, functionality, etc, the sound signature may vary. As you say, different algorithms to make X thing work.
What happens if AMP 15 is just 4.4mm only, are edition X users out of luck with a matching Liquid Metal faceplate? Does iBasso plan to make more faceplates to match future amp modules?
