You are, of course right, but there is more to it than that. The Rohm DACs process in 24 bit natively, whereas the SOC processes increments of 16 (16, 32, 64). Any time you change the bits in a digital file, you introduce quantization errors (among other distortions). Oversampling is similar to dither in that it moves any of those errors above the range at which the human ear can hear before the output stage where they can no longer be corrected. This is really the only way to give the appearance of elimination such errors, because they happen regardless when manipulating digital sound files.With 16x oversampling, Neutron will play with a native resolution of ROHM dacs. Native means the best a dac can play and should play with.
DX320 ROHM dac chips, Android 11, AMP11MK2s. *******NEW FW: 2.07*******
- Thread starter Paul - iBasso
- Tags
- ibasso ibasso dx320
Doug2507
If there are any lurkers with C9 looking to change for DX320, give me a shout.
ginandbacon
I may be able to test this tomorrow. I ordered one of these, mainly for testing power banks and laptop batteries but it does give the current temperature. Just to verify. I would be using stock/updated AMP11 with DX320, 4.4mm port using neutron with DSD256 content (or do I need to do any oversampling, never used neutron before). That or I can test the 2.5mm output.Btw, anyone can give me any feedback on operating temperatures while using full balanced sound and neutron dsd256? It's the heaviest load i can think of and i'd like to know if someone tested how hot it would get or if it can handles it ''coolly''.
It should also show. How much power it's using as well as the temperature of the battery. I won't know for sure until I get it in my hands though. I'm also wondering how it will handle the 2 batteries but having 2 batteries is becoming more common in laptops so I doubt it will be an issue.
MusicalDoc8
4.4mm output, dsd256 would be pretty heavy already, don'y know if oversampling chains over all to dsd or if if it's mutually exclusive. You could try based also on what you hear. Please mention the ambient temperature too!I may be able to test this tomorrow. I ordered one of these, mainly for testing power banks and laptop batteries but it does give the current temperature. Just to verify. I would be using stock/updated AMP11 with DX320, 4.4mm port using neutron with DSD256 content (or do I need to do any oversampling, never used neutron before). That or I can test the 2.5mm output.
For those who prefer FW updates via OTA, it's now available if you haven't noticed already. I am downloading it now
RIGATIO
I wouldnt do it An update via 660 Tool is recommended. I know its more problematic but at least youre sure that everything is done 100% well.For those who prefer FW updates via OTA, it's now available if you haven't noticed already. I am downloading it now
hung031086
I did that last night but it was still. I will wait for the OTA then.Unzip DX320FW-ota-2.02.zip to get to DX320_full_ota_2.02.834.zip, that is the one you want to copy.
Why wouldn't OTA be done well? I'm not trying to be difficult, just curious - have there been reported issues with the update via OTA?I wouldnt do it An update via 660 Tool is recommended. I know its more problematic but at least youre sure that everything is done 100% well.
RIGATIO
There were reports that it doesnt load a full version via OTA.Why wouldn't OTA be done well? I'm not trying to be difficult, just curious - have there been reported issues with the update via OTA?
Actually its very fast via the 660 Tool once you go through the manual.
ginandbacon
I did the first update OTA. It seemed smaller then the close to 900MB file from iBasso. When I put in the AMP13 card the volume knob was inverted (0 being the loudest). Someone suggested redoing the in upgrade manually. After I did the volume wheel issue was gone and no factory reset was needed. It also seemed to take longer to do the update then the OTA update. Ideally, they should be identical but downloading it on the DX320 from iBasso is going to be my method going forward.Why wouldn't OTA be done well? I'm not trying to be difficult, just curious - have there been reported issues with the update via OTA?
I understand the other tool was recommended but I don't want to do a factory reset unless absolutely needed. I e got an android phone so everything is tied to Google so doing a factory reset wouldn't be a big deal. Just doesn't seem necessary.
RIGATIO
Ok thanks.I did the first update OTA. It seemed smaller then the close to 900MB file from iBasso. When I put in the AMP13 card the volume knob was inverted (0 being the loudest). Someone suggested redoing the in upgrade manually. After I did the volume wheel issue was gone and no factory reset was needed. It also seemed to take longer to do the update then the OTA update. Ideally, they should be identical but downloading it on the DX320 from iBasso is going to be my method going forward.
I tried it via OTA and the file size was just slightly more than 900MB, so that's strange versus your experience. The iBasso site says it's about 904MB, and that sounds about right based on what was downloaded for me.
I don't have amp13 and don't intend to get it, so not too worried about that.
While a pain to do, I did factory reset twice and am now re-installed and re-downloading files.
Let's see how everything goes...thanks
ginandbacon
It seemed to take about five full (or close) battery drains and recharges before the battery settled in. That and the AMP13 card seems to drain the analog battery faster than the stock amp card.Seems like the battery life is quite good actually.
It won't affect DSD files but will affect PCM to DSD128/256 as long as the order of the chain is oversampling first (editable in Neutron settings). And from what I have read, they do chain together (serial, rather than parallel). Once converted to DSD the file will no longer be affected by DSP of the software (EQ, Tempo, compression, etc...)4.4mm output, dsd256 would be pretty heavy already, don'y know if oversampling chains over all to dsd or if if it's mutually exclusive. You could try based also on what you hear. Please mention the ambient temperature too!
jamato8
After doing some good burn in with the AMP13, getting excellent sound and more power than I thought it would put out. It easily brings great sound to the Utopia or the SR2 and any of my IEMs are an easy do. I have also been using it out to a couple of desktop amps, with excellent results.
