Search bar above thread, is your friend.Hugo 2 sounds better or dx320 sounds better?
From my memory, I pretty much agree.
There's quite the gap between Hugo 2 and Davethat means dx320 is dave level
I will have to kindly disagree here. Take a laptop for instance (another portable device powered by a battery and/or 110 circuit)?! You can remove the battery altogether and it will boot. The same goes for a dead (flat) battery. This means that the 110 circuit is using a MOSFET (or some other form of electric power distribution) to be both parallel and series with the battery. As a matter of fact some newer devices let you set when the 110 circuit will stop charging the battery so that you will have prolonged battery life if you use it mostly plugged in (my Gaming rig does it to 50%). If the DXxx has the ability to NOT charge while plugged in, it is already physically set up this way and simply needs the FW to include this from boot time, not just after already booted in the OS, and through a setting.The fact that the device won't power on if the battery is flat even when plunged in, has nothing to do with it. It's a safety feature
This I will have to also kindly disagree with. This may have been true many years ago with android devices. Even if it corrupts the OS itself, it will still have its ROM (now sure why they call it read only memory since you can write to it). And even if it manages to corrupt that, you can plug it in and use SSH or some other app from PC to reinstall the FW (which in this case happens to be the whole OS). Yes, you will lose all data you had, but it will restore it to factory default. The point is that is is VERY difficult to brick android devices nowadays unless you try really hard.This can brick the device.
Well sure, though at a much smaller scale, though I was referring primarily to SQ. My point is there are multiple assumptions being made in his... assumption, unless he thinks there isn't much of a gap between Hugo 2 and Dave, assuming he's heard both.Lol. Same with the 320 and Hugo 2 in price.
1. It should be somwhere in a package, it MUST be!Does anyone know if the DX300 glass screen protector will fit the 320? I can't seem to find any for the 320. Thanks!
It was I just didn't put I on good got a bunch of dust and lint underneath1. It should be somwhere in a package, it MUST be!
2. if not, the one from dx300 will fit, they have same screen size.
It should, they have same sizeIt was I just didn't put I on good got a bunch of dust and lint underneath. Thanks for the info.
Does a clear 300 case from Ali express fit 320?
Point 1: maybe yours does that, thankfully mine does not. Nor does my phone or my DX220.I will have to kindly disagree here. Take a laptop for instance (another portable device powered by a battery and/or 110 circuit)?! You can remove the battery altogether and it will boot. The same goes for a dead (flat) battery. This means that the 110 circuit is using a MOSFET (or some other form of electric power distribution) to be both parallel and series with the battery. As a matter of fact some newer devices let you set when the 110 circuit will stop charging the battery so that you will have prolonged battery life if you use it mostly plugged in (my Gaming rig does it to 50%). If the DXxx has the ability to NOT charge while plugged in, it is already physically set up this way and simply needs the FW to include this from boot time, not just after already booted in the OS, and through a setting.
This I will have to also kindly disagree with. This may have been true many years ago with android devices. Even if it corrupts the OS itself, it will still have its ROM (now sure why they call it read only memory since you can write to it). And even if it manages to corrupt that, you can plug it in and use SSH or some other app from PC to reinstall the FW (which in this case happens to be the whole OS). Yes, you will lose all data you had, but it will restore it to factory default. The point is that is is VERY difficult to brick android devices nowadays unless you try really hard.![]()
