DX320 ROHM dac chips, Android 11, AMP11MK2s. *******NEW FW: 2.07*******
May 22, 2023 at 12:15 PM Post #9,811 of 10,616
I got mine today. I installed from APKPure Google Play and when I try to start the store it says "this version of the application is not compatible with your device". Which version should I install? Thanks
May 22, 2023 at 2:39 PM Post #9,813 of 10,616
Working now. I must download older Google Play version. Strange..
I love the sound, much better than my M6U!
May 22, 2023 at 2:40 PM Post #9,814 of 10,616
I accidentally deleted APKPure before installing Google Play. However, you can sideload Google Play directly from Google. That's the way I went with, which also gave me confidence it wasn't modded in some way by APKPure. That app did not inspire confidence to me!
May 22, 2023 at 3:53 PM Post #9,817 of 10,616
How do you side load it ? Where is the download ?
@Wikinaut
It's been a while, but I used Chrome to download it. Just googled for Play Store and found an option to download the APK. IIRC, I had to change a security setting to allow it. But it wasn't complicated.
I'm probably drawing a blank, because I was mostly freaked out that I has just lost my ability to install anything! 😂
May 22, 2023 at 4:06 PM Post #9,818 of 10,616
May 22, 2023 at 4:10 PM Post #9,819 of 10,616
Just go to Apkpure site from any computer or DX320 browser, https://m.apkpure.com/google-play-store/com.android.vending
Download to your computer, drag it on SD or players memory like adding music or from the browser on the device. May get a security popup because it’s not from Google store. But when you are able to install, login to google play and update officially.
I already have the store app installed from APKPure app which came pre installed on the DX320. I was asking the user where he downloaded from in case there was a more up to date Google Store app to install 👍
Is there a way of updating the store app or is it done automatically like apps within the store ?
May 22, 2023 at 4:14 PM Post #9,820 of 10,616
It will update like any regular Android phone via auto or the play store. I always turn off auto update in the google play settings though i like to update manually.
May 22, 2023 at 6:16 PM Post #9,823 of 10,616
I might give this a try. I also don't like that APKpure always has updates for apps even though they are up to date on Google Play.
May 23, 2023 at 3:02 AM Post #9,824 of 10,616
Is the APK for Google Play down on APK Pure? If so, where is another place to go?
