Dx320 optimizing discussions
Nov 5, 2024 at 10:28 PM Post #106 of 147
Nov 10, 2024 at 1:05 PM Post #108 of 147
Sorry for the OT: do you have a link for the latest firmware for the DX320Max?
I do not. You can email Paul and ask for the link to it.
Nov 10, 2024 at 1:39 PM Post #110 of 147
Dec 12, 2024 at 8:18 PM Post #113 of 147
Hey all,
Wondering if someone here can help me. I just picked up a new 320, unrooted. I inserted a 512 GB mSD card and scanned the folder. Mango has duplicated every track in the DB. Fortunately, it hasn't replicated the actual files, but everything is duplicated and of course plays twice. Ive pulled the card rebooted, rescanned - nothing fixes it. Any ideas how to fix this?
Dec 12, 2024 at 8:27 PM Post #114 of 147
Hey all,
Settings -> Apps & notifications -> See All Apps -> Find Mango player in list and select it and then goto Storage and Cache and choose Clear storage. This will set Mango back to defaults and clear any data in it.
Dec 12, 2024 at 8:46 PM Post #115 of 147
Of Course, if it was a phone, I probably would have figured that out - but I seem no to connect dots today. Thanks so much!
Dec 12, 2024 at 8:49 PM Post #116 of 147
You are welcome and you can do the same thing with any app that gives you issues.
Dec 13, 2024 at 12:32 AM Post #118 of 147
Dec 14, 2024 at 10:24 PM Post #120 of 147
Well I'm curious if it's possible to make it sound better via the 4.4mm jack with amp14 using any of the options in developer. I also use Poweramp Equalizer and Qobuz. I'm curious if there's a few things I should do. I've already enabled the permissions for Poweramp.
For me getting a swissbit MicroSD improved SQ. You set the cache location to the microSD from internal memory. As far as I know I do not know of a setting in developer that will improve SQ. There are some settings that will improve performance which are in my guide for 320. I have found that just rooting and optimizing to help SQ as well as it gets rid of a bunch of not needed resource modules. Depending on your IEMs you can try high gain vs low. High for me gives music an extra punch/dynamic.
