psawjack
- Aug 28, 2015
Looks great I'll check it outHere is one great tool to disable your bloatware
https://adbappcontrol.com/en/
This is good to know so I quoted your post here.PCM to DSD in neutron is a degrading way to listen on dx320. The ROHM chips are pretty uniques. You can listen and compare for yourself
Also, the new firmware enabled Neutron without 64 bits processing. It also sound better without 64 but processing as well
It makes senses as 5Gz has a longer spectrum width and is more aggressively invasive. It is a great finding there. However, I don’t use streaming much, So I am pretty happy with it the way that it isEven better than Bluetooth hotspot, I created a spare SSID with my Amplifi Alien router that is only 2.4Ghz and the EMI noise with AMP13 is gone! I think it’s 5Ghz specifically that does it in. It’s completely silent when connected to 2.4Ghz WiFi and AMP13. I’m super stoked about that.
EDIT: 99.99% gone, sometimes I get an extremely faint crackle, but it’s light years better than 5Ghz.
EDIT 2: It returned when it reconnected to the 5Ghz when I stepped out of range with 2.4Ghz, but I forgot the 5Ghz and it’s gone. I really think I’m right on this one. 5Ghz WiFi does the AMP13 in.
I hear you. My offline library has fallen into disarray since streaming came along. And I can’t tell the difference between Tidal Masters and FLAC with my middle-aged ears so there’s just not much motivation on my part to fix it.It makes senses as 5Gz has a longer spectrum width and is more aggressively invasive. It is a great finding there. However, I don’t use streaming much, So I am pretty happy with it the way that it is
I talked to a guy who said that offline saved Qobuz sounds better than streaming it. I tried it on my iPhone -> Gryphon and it could be my imagination but I think he's rightI don't use Tidal, but the Qobuz app downloads and saves hi-res files for offline listening without any problems.
I use Qobuz in both offline and streaming mode every day, either on the DX320 or an iPhone 12 Pro Max. This difference is probably the settings used between the two modes. I don’t remember the default settings (have to delete and re-install)….but if the brain memory is correct, streaming is set to 320kb/s and the import setting is at least CD-16 bit/44.1khz. There are settings for both Cellular streaming/importing AND Wi-Fi streaming/importing.I talked to a guy who said that offline saved Qobuz sounds better than streaming it. I tried it on my iPhone -> Gryphon and it could be my imagination but I think he's right
Ya I have mine set to 24/192 on both but maybe the bit rate is slightly lower than the SD card read speed or something.I use Qobuz in both offline and streaming mode every day, either on the DX320 or an iPhone 12 Pro Max. This difference is probably the settings used between the two modes. I don’t remember the default settings (have to delete and re-install)….but if the brain memory is correct, streaming is set to 320kb/s and the import setting is at least CD-16 bit/44.1khz. There are settings for both Cellular streaming/importing AND Wi-Fi streaming/importing.
You meant the displayed bit rate is lower ? When streaming vs offline stored ?Ya I have mine set to 24/192 on both but maybe the bit rate is slightly lower than the SD card read speed or something.
No, I’m not sure how you could measure it. I could probably watch my router to see how much bandwidth is being used to stream but I’m not sure how you would do the same from an SD card. Maybe the guy was just messing with meYou meant the displayed bit rate is lower ? When streaming vs offline stored ?
So…..the question in my mind then becomes…. Did you specifically tell Qobuz to use the SD card in the DX320? It’s not the default setting. Qobuz uses the internal 320 memory unless you change the setting. And….fwiw, I tried this. In my case it made Qobuz unusable. It lagged like molasses for the simplest task. I deleted Qobuz and started over, only changed the settings for sound quality at the highest.Ya I have mine set to 24/192 on both but maybe the bit rate is slightly lower than the SD card read speed or something.
