Well there you go. That's why it sounds broken.
Thanks , I didn't know about this instructions.
Anyway I doubt if this is a real NOS filter since the 9038pro doesn't have inherent NOS and in reality no D/S modulating DAC can be NOS.
But we can discuss this elsewhere because we are out of topic.
Regarding the 9038prp
Oversampling Filter (OSF) Bypass
The oversampling FIR filter can be bypassed using bypass_osf in Register 37: Programmable FIR Configuration, sourcing
data directly into the IIR filter. The audio input should be oversampled at 8 x fs rate when OSF is bypassed to have the same
IIR filter bandwidth as PCM audio sampled at fs rate. For example, a signal with 44.1kHz sample rate can be oversampled
externally to 8 x 44.1kHz = 352.8kHz and then applied to the serial decoder in either I2S, LJ, or RJ format. The maximum
sample rate that can be applied is 1.536MHz (8 x 192kHz).
IIR Filter
Four filters with cutoffs at 47kHz, 50kHz, 60kHz, and 70kHz scaled by fs/44100 are selectable via iir_bw in Register 7: Filter.
Regarding the CS43198 NOS filter, of course it is not really NOS as you can read at the end of this manual.
https://www.google.com/url?sa=t&sou...oQFnoECAQQAQ&usg=AOvVaw0hysXT8EfpoRfvk9IR8YxR
This explains what they are doing in Gustard and they call it NOS.
BTW the notation NOS is wrong.
We are talking about
non - upsampling DAC if we need to be correct with engineering.
Oversampling is used during the recording procedure.
Real NOS is for example my DAC.
https://www.lab12.gr/product/dac1-reference/
