Ha! And then the joy of a 200 hour burn in...Perhaps when I receive it.
DX240 DAP. DAC ES9038PRO - NEW: AMP8MK2S .****** NEW Firmware! 2.01 *******
- Thread starter Paul - iBasso
AndySPb
- Jul 29, 2010
Hello guys, I need help!
it seems i bricked my dx240 when trying to install google play framework or services. it worked until I reboot the DAP.
now it cannot boot. first its stuck on iBasso Audio logo blinking, now the screen dont even show anything. Battery is charged (i know it)
how can I proceed hard reset, does anyone knows it? I left email request for help to iBasso but they didnt replied to me yet (will not?)
please help
please help
Have you tried holding the power button for 10 seconds? It's not a full reset but usually works when it freezes.Hello guys, I need help!
please help
AndySPb
- Jul 29, 2010
Yes sure, i have tried it, no any changes. screen is black like its turned off.Have you tried holding the power button for 10 seconds? It's not a full reset but usually works when it freezes.
lantian
- Dec 14, 2016
Sometimes feel like you need quite a bit more than 10seconds to get it unstuck, try for a bit longer couple of times holding it down for like 30 seconds atleast that's how it felt with dx220, with this one seems shorter but still longer than 10 seconds or it just takes it a while to register. If doesn't work try plugging in a charger and then powering it up, otherwise hold the powers button down for a while. Have had mine hand similarly 2 both times just letting it charge a bit and then holding down power button resolved issue.
Another option would be to get in bott manage or what ever that thing was called we had on dx200 and dx220 wipe cache and do a factory reset from there then booth back into android.
Otherwise last possibility is to use Snapdragon recovery tool with Windows. Best of luck and let us know how it works out.
AndySPb
- Jul 29, 2010
Thanks a lot for suggestions guys, appreciate it a lot. If anyone have more ideas, it would be great if you could find a time to type it here. Thanks!
@AndySPb my suggestion would be to download the official firmware tool 660playerupgradetools.zip and an image file like DX240_20230112_2.01.070_64G_img.zip
from iBasso's site: http://www.ibasso.com/uploadfiles/download/
You will find full instructions in the zip file to be able to factory reset your DX240
Good luck
Good luck
AndySPb
- Jul 29, 2010
Hi hi
Again thanks to all guys who tried to help me! You all saved my bricked dap =)
Hi hi, i have made it to work, flashed firmware finally using the tool you suggested. Thanks a lot for your kind help!@AndySPb my suggestion would be to download the official firmware tool 660playerupgradetools.zip and an image file like DX240_20230112_2.01.070_64G_img.zip
Good luck
jamato8
Glad to hear you got it working. That can be stressful. You can't really brick their daps. A piece of hardware would have to go bad but to software brick it, I have never seen as the tool is the same thing they use in their factory.Hi hi
AndySPb
- Jul 29, 2010
Actually i believe it was just pure luck that my dap finally let me boot it to the recovery mode (previously a half day it was like dead brick with black screen), seems it was tired of me pressing different combinations of these 3 buttons and volume wheel, hehe. That was really stressful.Glad to hear you got it working. That can be stressful. You can't really brick their daps. A piece of hardware would have to go bad but to software brick it, I have never seen as the tool is the same thing they use in their factory.
Man, you have wonderful photos in your sign by the way
Anyone else notice the battery on theirs losing charge when its shut down/switched off?
Fully charged mines last night, used for ~3 hours and shut it down at 70%, turned back on today and its at 61%!
I've only had it since Monday and already a little sceptical about keeping it tbh.
jamato8
No issues. I shut it down when not in use. Also, if yours was new, then the battery isn't even formed yet. I don't have any battery devices that don't require about 2 weeks of use for the battery to form and then hold a charge from iPhone, computers to Sony professional cameras. Even the Sony expensive batteries I use will lose some charge after being formed.Anyone else notice the battery on theirs losing charge when its shut down/switched off?
That makes sense, it's only its second charge, thanks for the explanation. I'll monitor it over the next two weeks.No issues. I shut it down when not in use. Also, if yours was new, then the battery isn't even formed yet. I don't have any battery devices that don't require about 2 weeks of use for the battery to form and then hold a charge from iPhone, computers to Sony professional cameras. Even the Sony expensive batteries I use will lose some charge after being formed.
Hopefully its fine as aside form that it runs great and sounds superb, don't want to return it
wizzman121
LOL, mine just arrived too. I am documenting this here so I do not mix them up since like you said as the new "2S" is not marked any different than the "2". Time to go plug it in!Let’s see what this is about!
You can only differentiate between mk2 and mk2s by looking at their caps. They’re both labeled “amp 8 mk2” on the faceplate and actual hardware itself.
*Fixed the labels!
Total: 6 (members: 0, guests: 6)
