Here are the AMP cards side by side. Still burning in the caps on the AMP1MK3, impressions so far are favorable.
You have to download it. Then unzip the download and the FW is there. Tried the 80% battery saver and it didn't work then rebooted and it works. Great feature.There is a new update out. Has anyone tried to download and install it? I have, and it says, "Failed to install update package!"
It is common and saves the battery and it will still charge to 100% normally if desired. Batteries charged to 80% and discharged to 20% last much longer than full charge and discharge. My Mac computer does this as do some other battery operating items. It is the smart way to charge unless you need the full 100%.Why would you wanna stop battery charging after 80%? Seems like using your player on a regular basis after only 80% battery charge would make battery performance & longevity worse, not better. No reason is given for why or when you might wanna use this.
Working.For those who are having trouble with the update, please follow this: Download update > unzip DX240FW-v1.03 > Double click folder > Copy Zip OTA > Paste OTA in SD or Internal Root > Settings > System > Updater > Three dots in upper right corner > Local Update > Click Zip
Follow this process, and you will be able to update to the current version for the DX240. RH
