DX200=Affordable High End Audio. Dual ES9028Pro dacs. AMP1, AMP3, AMP5, AMP7 & AMP8 ***Firmware support now up for AMP9***
Apr 22, 2018 at 1:08 AM Post #13,038 of 22,021
wow. im currently using amp3 and found it really good already and not sure how good the AMP4s is. Anyway, hope IBasso will come out something good later. Its a good product and everyone likes it and its a good business and there is no reason why they wont produce it again or come up something better.
Apr 22, 2018 at 1:56 AM Post #13,039 of 22,021
First post on dx200 forum
Anyway, I have just purchased the dx200 as it seemed a little different to my other players. I just called my supplier in HK and it seems that no stock here too. Anyway, the supplier mentioned that I should wait for amp8 as it will also be 4.4mm too and it should not be a limited version.
Take this with a grain of salt. That is what they said. So if this is true, then it makes me think what would be amp7.
Apr 22, 2018 at 4:17 AM Post #13,041 of 22,021
I just hope we can have an amp with both 2.5 and 4.4 balanced LOL. I’m having a dilemma whether I should terminate all my cables to 4.4 or keep them at 2.5. Hahaha.
Apr 22, 2018 at 4:24 AM Post #13,044 of 22,021
Apr 22, 2018 at 8:40 AM Post #13,049 of 22,021
Adapter
Apr 22, 2018 at 9:35 AM Post #13,050 of 22,021
Old cables, I think dont need to re terminate, just use adapter.
If you buy new cable, go for 4.4
Or re terminate to use dita awesome plug.
