Hi all, looking for a Micro SD card for my upcoming DX200 and since I'm new in the world of DAP, I'm wondering if the quality/performance of the card is really important. Sure I don't plan to buy a cheap card but is there a performance difference in audio application between let's say a Samsung Evo+, Sandisk Ultra or Sandisk Extreme Pro?
I assume the quality of the card have more to do with reliability concern than audible difference but want to ask experimented users here.
Picked up my DX200 and heard a rattling sound, as if a screw got loose inside. Took off the case and removed the amp. Eventually stopped when I turned it around enough. Everything still works fine. Should I disassemble?
It isn't hard to take apart. The metal that covers the volume control, a screw under a piece of white tape and a couple of other obvious black screws and the two screws where the amp would fit next to the case. I would guess a loose screw.
If you email me I can send you a video for disassembly. There is a piece of tape that is over a screw for warranty purposes but since I authorize this your warranty would be intact. I apologize for any inconvenience.
@Paul - iBasso, you are too cool man. Thanks for taking care of all of your customers. We all will be loyal because of great products and great help from you! Love my dx200. I listen to it everyday. Merry Christmas to everyone!
I have heard legendary ibasso support all the way to my country. I thought it was stuff of fanboy myth. After reading this, i now fully believe it. I would not hesitate buying ibasso product in future.
I was wondering if anyone has heard the HD800S with the dx200? I really want those headphones but I don’t want to buy an amp just for those. I am hoping the balanced output is enough for those headphones. Thanks for the answers.
