I've got an iBasso DX200/AMP2 and Shure SE846 setup and am looking to upgrade my IEM's. I would like a good amount of accurate bass with lots of fatigue-free detail.
My budget is about £1000. As I can't listen to anything due to living in Jersey, Channel Islands, I have to rely on people's opinions and reviews. What should I be shortlisting? The Campfire Audio Vega looks to fit the bill?
I had the IT03 and sold it today on eBay, at a huge loss, after only one day's use. I couldn't get decent bass with any of the included tips. I hope the IT04 doesn't have that lug on it, as it's the only IEM I have used that had it, and the only IEM that I couldn't get a decent seal.
The medium tips included with my Shure SE846 fits perfectly every time. The IT03's made my ears sore with all the messing around trying to get a seal.
I had the IT03 and sold the today, at a huge loss, after only one day's use. I couldn't get decent bass with any of the included tips. I hope the IT04 doesn't have that lug on it, as it's the only IEM I have used that had it, and the only IEM that I couldn't get a decent seal.
bi-flange tips worked great for me and provide great bass. i also couldn't find an included tip that was to my liking, but with bi-flange, absolutely perfect fit and seal.
Spinfits are hit'n'miss for different people. They are dependent on anatomy of your earcanal...
I think you really jumped the gun on IT03. I mean, it's too late to talk now, but you should have posted with your concerns to get some feedback. For example, I have been using these eartips from Penon with a high success, only $3.99 shipped: http://penonaudio.com/3-Pairs-In-ear-Silicone-Eartips
Bass is all about the seal, and sometimes you might not even get a good enough seal with the largest tip if the silicone cap part is too soft. For example, those tips from Penon have a thicker stem and firmer cap. If that doesn't work, try foam eartips, they will give you the best seal, and usually foamies enhance the low end and tame down the upper end.
