ucanuup
- Mar 7, 2014
Ill try my man, just playing music 3 min so far, but, well..actually i am seriously impressed..
Whatever Paul has been about here all this time telling us to be patient its true my friends..
My 1A has 200 hiurs now and im very surprised i find dx200 clearer and warmer too actually..hmm
Which headphones did you use?
Can I report this to the moderator of this thread?
I feel like I've been singled out and victimised because someone has a negative impression of me because of my English? That's discrimination in the most obvious way.
And sounding so forgiving and generous after that rant is very elitist in my books.
I'm sorry Steve but this is not acceptable.
An apology is in order else we can take this to the moderators.
I really apologise to everyone and Paul for this matter. It seems my opinion is regarded unacceptable and elitist by one reader and I'm getting flamed for it. Not letting this go off.
Moderator please advise. Thank you.
The manual has been great.
It helped me to work out how to mount it on my Macbook pro.
Also to scan the music is two swipes to the right of the music player (a friend showed me, i thought it only went once).
I did buy a new micro sd card and then promptly loaded the music to the internal memory, Doh!
Next to update the Firmware
This is interesting. Here I am supporting the new guys to the community. The ones who may not have the technical training or the best testing instruments from a person who has literally just tried to turn the tables with misdirection because he was called on his statement. I sounded forgiving because I am forgiving and generous...it has nothing to do with you. That was elitist? Compared to your comments earlier? LOL.
You want an apology? Sure, here, and know that it's absolutely given with an incredulous smile. I'm sorry you took my rant as singling you out.
Steve from NYC
The AT 70x,top pairing, Vega next
Any chance for some of the DX200 owners to put up a video on setting up (Mac?), loading music and some of the player?
Maybe even sharing some nice easter eggs found during the expeirnce as well?
I concur with the 1A comparison (my 1A has 400h at least), maybe I'll nuance warm as it's not overly warm or much warmer than the 1A. I would rather say it's significantly fuller at least with the Vega, especially lower mids which explain the warmer feeling. The DX200 is getting better every hour I put on it, it's getting more and more "musical". I think we should assume things are going to improve / change quite a bit as described by some even the first 10/20 hours (heck, at 5 hours I already find a difference or its my brain). One aspect that impresses me is how "fast" this player is, as in it's so nimble with complex fast tempo arrangements.
On a sidenote, I noticed charging is fast probably the benefits of the USB type C specs. Also, kudos iBasso for the quality of the charging cable. Note I experienced an issue with an external battery I use when I need to charge my DAPs without being tied to a plug : the amp meter when wild to the max and the external battery simply shut down... I guess it's drawing too much power
You're in for a treat with the Vega
Do you have android devices?
It's just purely the same experience as any device using Android File Transfer is almost as straightforward as the finder.
MacOS do not natively support MTP protocol used by Android devices, so you won't be able to mount your DX200 as a drive (like my DX90 for example). Yet it's not too difficult:
- download and install on your application folder Android File Transfer
- plugin your DX200 to your Mac using the USB cable
- unlock your DX200 if needed
- swipe down from the top screen, and you will see a USB "widget"
- touch it to open the options list, and select "File Transfer"
This should automatically launch Android File Transfer app (if not try to launch the app), giving you access to the internal memory as well as memory card folders. You can drag and drop folders/files from the Finder to Android File Transfer.
