- Oct 14, 2013
FLAC takes a lot more than MP3 in the battery %. If you do only FLACs, about 6-7 hours is expected. If it is lower than that, your battery is probably need replacement
I'm using high gain at about 90-100 with my IT01 (16ohm/108dB). I have the latest iBasso firmware with nothing else downloaded. So it's only running the standard processes.
OK, thank you! It is too high volume to measure the battery life. For instance, I never used volume above 70 (high gain) with any iBasso IEMs and AMPs continuously. An no - I don't listen those modern overcompressed recordings! For them, even volume 70 is too loud for me.
So now you have at least half of the answer Then, you may try IEMs with higher impedance and higher sensitivity, to add more to the playback time.
Thank you my friend. Waiting amp8 arrives me and maybe I'll ask you something more, just for a final check before to do everything to avoid problem!I adjusted the number of images to the order of Twister 6 Reviews page.
1. Nichicon 470 uF Remove the orange Siemens 220uF and replace it with a silver Nichicon 470uF.
2.1uF MLCC The blue color of the image is made by TDK which was in part BOX. KEMET on the Reviews page is yellow.
3. TK-Sheet I pasted it on IC and Inductors. Also on the back side.
4. NIPPON CHEMI-CON KZH 100uF.
With IT04 my volume is 80, more than 80 is just noise for me.I was thinking about getting some IT04's, but I think they measure about the same as the IT01.
PS in point 1 you speak about orange but I see it is white
ciao!
yes @Whitigir I saw it, but I also seeing photo where it is white.
While the mouser capacitors should be grey.
So this creates some confusion to me.
I think u need to reconfirm to Him, alrd get the confirmation that the dealer was to hold my DX200 purchase, wait the new model come....Before Dx200 released, there was this dedicated thread for it. And it comes like 6 months later.
I would expect similar ? But who know ? My guess is that @Paul - iBasso wouod confirm again what he said a few months back
Well, seeing that we tagged him in a couple posts for this and he is not responding, then we just need to wait a bit moreI think u need to reconfirm to Him, alrd get the confirmation that the dealer was to hold my DX200 purchase, wait the new model come....
ciao!
The one that looks white is Nichicon 470 uF after exchange.
Leave untouched TK 220uF as it is.
Can not see Siemens (Orange) to exchange when opening the case?
TK 220 uF = Toshin Kogyo (TK).
A little bigger one is Nichicon 470uF exchanged.
If your AMP 8 is a Conductive polymer Aluminum solid electrolytic capacitor
It may not need to be replaced if it is.
please check.
