- Oct 14, 2013
Hold power button so it can turn off.Even if I factory reset it just keeps going round in circles
Download newest Oreo
Follow instruction
Do what I said, I had been thereMy dap won't get past the ibasxo dx200 reference player screen and then restarts again. I can get in to dap to go to system upfate
I posted this on the DSD512 thread, but thought I’d ask here:
I can’t seem to get Neutron to play native DSD512. It only renders audio if DSD over PCM is set to on. Is there something I’m missing?
Usually, for a Delta Sigma IC chip, the like of ES9028Pros. They will have to split the DSD into multi bit, and so as long as it is multi-bit, it is DOP anyways.
That is why some SD-DAC is capable of DSD512 and some isn’t. It is simply not powerful enough to do that processing. For example, AK4490EQ vs AK4497EQ ?
To be able to process any DSD512, it needs not only great processing speed, but lower noise too. Both Xmos208 and ES9028Pros inside the Dx200 is capable of that . The Dx200 is an awesome device
Real Native DSD will remain 1 bit from the source all the way to the low/high pass filter ...which requires a custom a custom DAC chip or a coded FPGA, and an FPGA for DSP too
Looking good and nice. Where did you get those BG PK or FK? Do they have the same values? What is the big blue cap BC?).
I am interested in the details of those blackgate , May we know more ? Thank you
Lurker had a post where I think he was saying that you could set DSD to PCM to “off” and gain native DSD playback. However, if i understand you correctly I should just leave DSD to PCM set to “on.” Is that right?
