xnuthecaveman
- Mar 28, 2012
Maybe an upgrade program/modding for non-Ti Dx200
The best post/comment I have seen in a whileSame reason some people write their name at the end of each post when it's part of their username. Who knows?
Fuhran
Is your WiFi connection 5ghz? If not you will hear static/lag/noise.I've had dx200 for a few hours....
RF noise at times (noticeable in quiet passages)
Laggy Tidal, typing or searching in Tidal makes it feel like dx200 has 5mb of ram to work with...
Sound is ok out of amp1. Decent, amp 1 does not beat mojo in my opinion, but I got amp4s to try, waiting on a 4.4mm cable.
Version. 2.8.198
Hiss is decent but quieter than mojo.
Ui is quick and capable (except Tidal)
When I change songs in Tidal, the dx200 clicks and pops between tracks...
I have to give it more time but so far its a sub par experience. If Tidal worked fine I can live with it, but I'm allready looking to upgrade or at least side grade... Idk, so far does not best MojoPoly, sound wise anyway, but amp1 is outdated right? So I can't judge that.
I have 2.4 and 5g,i switched to 5g and still hear itIs your WiFi connection 5ghz? If not you will hear static/lag/noise.
Did you get the DX200 new or used? I would do a factory reset. I don't get any RF noise but have found that reset can clear up problems. I also have the Mojo and with a burned in AMP1 find the DX200 different but an equal and in some areas a little better. With AMP8 it totally pulls away and with AMP4s, a number of areas I prefer the DX200 in.When using Tidal, I hear a mild RF noise.... Oh man.. This is a bummer for me..... I thought no RF noise...
I would do a factory reset anyway. I loaded Lurker's FW with the Batch Tool.Got it used, but switching to 5g helped a lot, at times a small static.
But why is Tidal so so so slow.... Also couldn't figure out how to do lurker fw. I wish I could put the lurker fw on. Sd card and load that way
Was thinking of getting dx200 using mainly tidal offline is it really that slow ?
