And AMP7 is in the house Some fun times tonight!
Except from AMP6 (I didn't get DX150, but I might get DX120) I will have owned every AMP ever built!
cant wait to hear your verdict on amp7 david as that may well be my next purchase for the dx200
Did you try/get AMP7?
Just been an hour but I am very impressed, I need more time but it's clearly way better than AMP5 and if it's not at the same level as AMP8 it's at least on the same plane field as AMP8!
I feel like it's been tuned with a very similar philosophy : extended yet controlled and textured bass, musical but articulate mids, with great extension and detail up top while retaining smoothness. And soundstage is very similar which I didn't expect... I have to check imaging and technicalities but AMP7 is immensely enjoyable.
It's great to be able to enjoy AMP8 like performance with single ended gear I own... Final E5000 are just singing well beyond what they should be capable of it's just mind blowing for 250€ IEMs, I still can't believe it...
After tuning for a long while between original AMP8 and modified one. AC/DC sounds wonderful with greater slam, better controlled bass, fuller dynamics, cleaner sound, and richer details.
Very nice! All of those Tantalum were replaced, and newer caps like what you just had been using. Definitely a great place to enjoy a modified Amp8 .May I ask what are the caps are you using? Are there any more modification besides those 2 caps in the picture? Thank you.
Amp7 better than amp 5? Wow..can u explain more? Im primarily using amp5 for my Final Audio Lab 1. In what way issit it better..colour me curious
Yes, but with noisy charger, it will be noisy and leak into your system. Use a clean charger out of a good outletIs it ok to charge the DX200 while it is in use?
Nope! I am not a fan of single ended and my Cables isn’t SE, given that I can make it, but I am a very lazy modder....I don’t do unnecessary things. Once I have the article on Amp8 up, people can follow to play with other modules too !
Yeah, I totally understand your point , which is never an issue for me . So balanced it isI also prefer balanced but some gear has single ended termination with non detachable cables, AMP7 is handy
