ngd3
- Apr 8, 2017
What are the advantages to lurker's fw? Is it a no brainer to install?
No brainer installWhat are the advantages to lurker's fw? Is it a no brainer to install?
I strongly disagree with that as a broad statement. Some gear changes more drastically than others with burn in. Some gear may not change at all. For example the Campfire DD IEMs change a LOT with burn in, some BA IEMs may not. With the former it's a very noticeable change - in a very glaringly obvious way that makes it seem like two different IEMs. And yes I was able to A/B a fully burned in vs a brand new one twice.I've said/typed it before I'll say/type it again:
Burn-in is overrated. Just listen to the thing and grow old together. This is my mantra for every device I acquire. I can never tell on what the sound was like on day one versus what it then sounds like on day two hundred forty seven. Listen and enjoy.
And I do agree that there is no need to avoid listening to anything while burning in - just listen as you go and enjoy the ride.
Agreed!Yes. That's the gist of my comment to those sweating out the details. I don't seek out to specifically "burn" in a device. In Audiophileland it's whatever floats people's boats.
I let mine play non stop for 200 hours, charging it as it needed and not on constant charge. As for DX200+Amp 8+ Andromeda, match made in heaven, go for it.Hi everybody, I'm about to order a DX200 and need advice on how to burn it in properly. I mean, I know how it works, but is it ok to leave it running non-stop for a week? Isn't it dangerous for the item?
I also wanted to buy an extra amp, and was thinking about Amp4 as I read it was probably the best and had the largest soundstage. But it's not available locally and I thought maybe I should get Amp8. And I use Andromeda. What do you guys think about Amp8 against Amp4 and it's pairing with Andromeda? I tried to read the thread and it's a bit overwhelming. I would appreciate any comment, thanks in advance!
Good tip. And if one really, truly loves their DX200/DX200Cu/DX200Ti KY Jelly works a treat, too.Can’t get enough of your Titanium Dx200 ? How about cares given for something as precious as Pure Titanium on your Dx200 ?
Apply Carnauba Wax on it for a protection coating, for shine, and for better look just like Watches!
It also helps prevent excessive burn during burn in.Good tip. And if one really, truly loves their DX200/DX200Cu/DX200Ti KY Jelly works a treat, too.
[edit]-typo
Dx200Ti is also sharing the faceplate and screen design of Dx150 instead of the older one on Dx200/Cu. The reason is ?
